Results 1 to 8 of 8
Thread: 1st House, First pool. Advice?
    Hi everyone. Iím sure you guys see a lot of these posts this time of year, sorry for thisÖ Please bear with my noob first post. I just want to say hello & get some advice.
    I just signed the purchase contract on my first house. The house will be coming with my first pool. We never had a pool growing up, so my knowledge of maintenance/ upkeep is minimal to zero.
    Pool is IG, 26-28k gallons based on some paperwork I have from a work order, enclosed, gunite, the pool was renovated in 2010 (about $17k worth) The pump, filter, heat pump were replaced then. I do not know the brand & model specifics. I will find out. The pool has been winterized, but I do not think it was opened last season. The seller is going to clean and open the pool prior to our closing date. My plan is to be there when the pool company comes to do the work (seller lives out of state, so this may be hard to arrange). I am hoping the guys that do the opening, can give me a crash course on how the pump valves work, how to clean the filter, etc.
    Once the pool is open and the levels are good, I am thinking of doing the BBB method as it sounds both easy & cost effective. My current hobby (about 15 years) is keeping saltwater reef aquariums. Itís a rather expensive hobby (but rewarding). I hope that this hobby will help me transition into being a pool owner. As with my reef tanks, I have no issues sinking money into quality water test kits & fully accept the need to test regularly. I assume the pool will be a similar idea. Save money where I can, donít cut corners where I shouldnít & find a community that can help me learn the difference.
    I am very excited about having the pool & I think my young family will get a LOT of use out of it. (I currently pay around $140 a month for our gym memberships that we really only use to swim). Just looking for some advice on getting started on the pool venture & what to look for/ ask questions about after we get settled in.
    26k-28k enclosed IG rectangular gunite pool, Attached spa, Hayward cartridge filter, 2 HP pump, AC-1500 HP
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: 1st House, First pool. Advice?
    Welcome to tfp, Cubist
    If you haven't already...make sure you spend some time in poolschool (link at upper right), test kit info in this article: http://www.troublefreepool.com/pool-...kit_comparison...the tf-100 is the most bang for buck.
    Quote Originally Posted by linen
    Thanks. I did a lot of reading in the Pool School last night when I found the site. A LOT of great info in there. Bookmarked for sure. I'm planning to order the tf-100 kit and have it in hand when we move in.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Sounds like your already on the right path, another useful tool is the 'THe Pool calculator', it will allow you to plug in your tests results and tell you the dosages, if any.
    If you husband looks after a salt water aquarium I'll bet he'll have no problems implementing BBB.
    Quote Originally Posted by cramar
    Yep. Already have the pool calculator installed on my phone.
    No husband BTW. The tanks are mine.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    I think she looks after those reef tanks, which in my experience will make caring for her pool a breeze.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Quote Originally Posted by elwood58
    That's kind of what I'm hoping for. I assume it's the same basic principal. Keep an eye on water quality & chemical levels in order to make minor corrections when needed & this will allow me to avoid major problems. with reef tanks, the bigger the tank volume the more "fudge factor" you have with chemical, temp, salinity swings. with a smaller tank swings happen quite quickly & I have to really be on top of things. My 90 gallon reef at home is very stable. My 5 gallon tank at my office takes a bit more work. I'm hoping with 26,000 or so gallons to work with I will have smooth sailing.
    38,268
    Welcome to TFP!!!
    Please add your pool details and location as described HERE as it will help us help you.
