Thread: Testing TA
    May 2009
    Trenton NJ
    497
    Testing TA
    For some reason when I test for TA the color goes from green to pale yellow instead of red. I tested 3 separate times. I thought it maybe the titrant solution was bad so I tried with my new kit (Taylor k2006) and same reaction. I did remember to wipe bottle with damp tissue between drops.
    I did open early this year and water is cold. Would that affect test. My ph is 7.8
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Testing TA
    High FC can make the TA test change from green>pink to blue>yellow.
    The exact shade doesn't matter as much as the change.
    38,371
    Re: Testing TA
    Add drops til the color does not change:
    extended-test-kit-directions-t25081.html#p206395
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Re: Testing TA
    Thanks! I never read this procedure thoroughly enough. I've always just added until the color changes to red (or pinkish) counting the last drop. Don't think I added a drop after that to see if it changed again. Will need to try the extra drops tonight. Magnetic stirrer sure makes a couple of these tests easier!
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    May 2009
    Trenton NJ
    497
    Re: Testing TA
    Quote Originally Posted by Richard320
    Ok...that's what it is then. I am in the middle of shocking. My FC is 28. My cya is 70,I have a swg but it is off til I am done shocking. It's amazing how good the water looks opening early. After 2 days I am almost there. Last year I opened 3rd week in may n it was a swamp.
