Thread: ADVICE IF SALTY WATER FROM WELL IS SUITABLE
    Hello guys,
    Please consult if my water is suitable for a swimming pool.
    The pool is near the sea and the water is from a well, so the water that comes out is a bit salty.
    Conductivity: 3230 ?S/cm
    Chlorine Ions: 405mg/l (question: is this the FC?)
    Total Hardness: 405ppm CaCO3
    Total Salts: 2080 ppm
    Thank you.
    40K Gal. IG w/ Stainless walls and concrete bottom
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: ADVICE IF SALTY WATER FROM WELL IS SUITABLE
    The salt should not be a problem, as many put salt in up to those levels to improve water feel. Your issue is likely to be CH. you will have to closely control pH to limit scaling. You do not list the pH of your fill water.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    That water's fine...the salt content is not very high, and the calcium hardness will be a portion of the total hardness, so also OK. FC is free chlorine, and you won't have any of that in your well.
