Results 1 to 12 of 12
Thread: Testing Calcium
    RaviePoolGirl's Avatar
    Nov 2011
    Napa, CA
    47
    Testing Calcium
    My Calcium level is high and I just have to deal with it for now. I run 550's to 650's. I want to know what I can dilute my sample with so I am not using as much testing reagents and maybe I can get a more precise number. Will distilled water work? 50/50?
    20,000 gal inground hourglass shape with 7' Hot Tub with overflow; Gunite
    Hayward TriStar 1.85/.22 THP - Hayward cartrige filter- SWG.
    Hayward Gas Heater
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: Testing Calcium
    Distilled and 50/50 is the way to go. Tap water adds unwanted minerals and differing ratios makes the math a little fuzzier.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Nov 2011
    Napa, CA
    47
    Re: Testing Calcium
    Thank You! I will do that
    Hayward Gas Heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,974
    Re: Testing Calcium
    Quote Originally Posted by RaviePoolGirl
    HA! I laugh at your puny numbers!
    Use 10 ml sample, 10 drops of R-0010, then each drop of R-0012 counts as 25 ppm. The extended directions say 3 drops of R-0011, but I use 5 and the number hasn't changed. When you get up there, who cares if it's 810, 825, or 840? The difference is minimal as a percentage.
    If you don't have a speedstir, I pity you. It must take forever to run the test. For what its worth, my CH dropped dramatically just by testing with the speedstir. Thorough mixing is essential. Sometimes it seems to hang at dark blue (almost indigo) and another minute of high speed swirling will get it to go sky blue with no extra reagent.
    38,262
    Re: Testing Calcium
    You can also use a 10 mL sample and then each drop is 25ppm. Check out the extended testing instructions sticky in the testing forum.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Nov 2011
    Napa, CA
    47
    Re: Testing Calcium
    Ha Ha Rich, I agree. What does it matter with numbers so high I feel like my color is such a gradual change I just don't know when to call it done. I was actually hoping that I would see a more dramatic change to know it is done. Maybe to 10cc sample would suffice as well. And I do have a "Speed Stir"!!!!!
    Hayward Gas Heater
    Richard320's Avatar
    Jan 2010
    18,974
    Re: Testing Calcium
    10 ml sample. 10 drops r-0012. Spin it one cycle. Then 10 drops r-0010. Spin again. 5 drops r-0011, spin until the purple blob is dispersed. Then add another 10 drops of r-0012. That will get you in the ballpark for 500+ CH. If it's still pinkish, add drops 2 at a time. When it starts turning purple or indigo, slow down and do the drops one at a time and let it go a full cycle between drops. When it turns SKY BLUE, like this,, you're done. Not dark blue. Sky blue.
    That's how I do it. Except I do the rough dump starting at 700 CH and go up slowly from there.
    Nov 2011
    Napa, CA
    47
    Re: Testing Calcium
    Ok, I will try that [SMILING FACE WITH SMILING EYES]
    Hayward Gas Heater
    Apr 2013
    Phoenix AZ
    20
    Re: Testing Calcium
    So is there any way to lower CH? Or do you have to drain and refill with no/low CH water?
    ~20,000 gal in-ground plaster pool, 3/4 HP pump, ~3 sqft sand filter (newly replaced May 2013), TF-100 test kit with Speed Stir!
    Nov 2011
    Napa, CA
    47
    Re: Testing Calcium
    Drain, refill is cheapest option. I've heard of having a water treatment done at the pool like Reverse Osmosis. Someone please correct me if I'm wrong.
    Sorry So Short.
    Hayward Gas Heater
    Feb 2008
    Denton, TX
    5,061
    Re: Testing Calcium
    Quote Originally Posted by burine
    Depending on where you live, you may be able to use a reverse osmosis company. Most people just do drains and refills. But if your fill water is the culrpit as it is for most in the desert SW, it doesn't help much. Some people, like Richard320 mentioned, have to deal with high CH levels no matter what. It can be done by managing you CSI in other ways such as by running lower pH and TA levels. Just have to get creative if you are in that situation.
    From this point forward, only use the 10 ml sample, high concentration test for CH. You might go ahead and check your tap water and see what the CH there is. Keep in mind too that the CH in municipal water can vary at times since some places use multiple sources depending on the time of year.
    Richard320's Avatar
    Jan 2010
    18,974
    Re: Testing Calcium
    Quote Originally Posted by 257WbyMag
    She's just, uh...spiraled...yeah, that will get past the censors
    The Napa Valley has exceptionally hard water. And to think people pay big money for the crud that comes out her tap! Ever hear of Calistoga Mineral Water?
