Results 1 to 7 of 7
Thread: 4 days in
    4 days in
    Hello everyone. I've been reading up on this site since last year (1st full summer with pool), and it's been very helpful. I opened my pool this past Sunday to find a swamp like many others. Tested water with Taylor K-2006 and came up with the following: FC-0, TA-90, PH-7.0, CYA- Less than 30 (could still see black dot after tube was filled) I raised PH to 7.2, and put enough stabilizer in a sock to raise CYA by 20ppm, and placed in the skimmer. I then began the shock process by raising and holding FC between 15 & 20 ppm. I also added DE to my sand filter as that seemed to help a lot last year. So here is my question: When fighting algae, is it normal to notice the clarity of your water improving faster than the change in color? It's only been 4 days, but I can almost see the bottom of my entire pool, while the color has barely changed. It did go from dark swamp green, to a bright green, but the daily visual improvement has been in clarity and not so much color. Just curious because everyone else seems to see color change from green to grayish white, then start to clear. Thanks!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: 4 days in
    Are you still testing the water and keeping the FC at shock level?
    Jeff
    Re: 4 days in
    Yea. Been testing and adjusting 2-3 times a day. Steady FC between 15-20ppm.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: 4 days in
    Alrighty, I got that out of the way. I want to make sure you are keeping an eye on the PSI of your filter with the DE in it. That will usually go up fast when you have algae. The DE is probably doing a great job cleaning out dead garbage from the water, but you still have algae that needs to be killed by shocking.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: 4 days in
    I'd give it some time it's a process. Just keep FC levels up.
    From what I've seen the clarity comes before the green goes away. Your on your way. Stay on top of it.
    Jeff
    Re: 4 days in
    Quote Originally Posted by Vette
    I'll try to post some pix soon. Yea, I add DE until my PSI increases by 1. After a day it seems to jump up another 6-7 PSI and stop. That's when I backwash it. I know it's only 4 days, and I'm sure there is a lot of work to do to kill the algae, I was just curious if anyone else had noticed the same progression.
    Re: 4 days in
    Quote Originally Posted by pwrstrk
    Cool. That's what I was hoping to hear. Thanks.
