Results 1 to 7 of 7
Thread: adding borax question
    Hello
    I accidentally added the borax first is it ok to add the muriatic acid next?
    thanks
    32 ft x 16 ft x 52 in Ultra Frame™ Rectangular Pool Set w/ Sand Filter Pump & Saltwater System
    Above ground Vinyl
    Krystal Clear™ Sand Filter Pump and Saltwater System with 2,650 gallon (10,030 L) per hour flow rate
    Wanda the whale and Intex automatic pool cleaner
    Re: adding borax question
    Welcome to TFP!
    You should add the acid as soon as possible. High PH can lead to calcium scale and/or metal staining. The less time you leave the PH high the better.
    ok thanks so much for the fast answer. I was in the process of putting the first half before scrubbing and am now adding muriatic, going to scrub it and then add the other half of borax and muriatic.
    Again thank you
    Above ground Vinyl
    38,305
    Just to confirm. What is your TA? You lowered it first before starting to add the borates right?
    Yes I had it to the recommended level for a swg vinyl above ground pool
    Above ground Vinyl
    38,305
    Above ground Vinyl
