Thread: building a deck around the skimmer
    we are building a deck around our agp and we are still trying to figure out the best way of going around the skimmer and still having easy access to it. If someone could give me some ideas or pictures it would be greatly appreciated!
    Thanks!
    Oct 2012
    Central Ohio
    180
    Re: building a deck around the skimmer
    Can you add a removable panel,so the skimmer can be accessed from the top of the deck?The panel would only have to be big enough to allow the lid of the skimmer to be removed for cleaning.
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    38,284
    Welcome to TFP!!!
    A panel that lifts off would work or even put some flat hinges on it to flip open (although then you may be stepping on the hinges)
    That's probably what we are gonna do. Just trying to see if there were some better ideas out there.
    Thanks! (:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Put the deck on the other side of the pool! Just a thought
    If I used a piano hinge, I'd do it this way ???? where Omega is the hinge and the part on the right swings up out of the way. That keeps the hot metal below bare feet!
