Thread: 16x48 ultra frame help
    Mar 2013
    Cypress, TX
    6
    So I have an intex 16x48 ultra frame that is a year old now. I fought so much last season with thst crappy cartridge filter and pump, that I'm taking the plunge and getting the sand filter now. Which size do I need to get? The wife and I are in a debste bc I want the 2650gph abd she says save the money and get the 1600gph. Also,should I get the SWG or not? I just dont want to struggle with it like last year. Thanks!
    ~10,500gal IG Plaster; Hayward Sand Filter; Kreepy Krawly cleaner
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: 16x48 ultra frame help
    Both will work for you pool and be much better than the cartridge filter your pool came with, but if you want to hook a suction side vacuum up, the 2650 will be better.
    Quote Originally Posted by cmcraig
    I would not get the one that is built into the pump/filter combo. These things never fail at the same time.
    Mar 2013
    Cypress, TX
    6
    Great info. I hadn't intended to get the all in one unit for that reason. Would it be beneficial? I'll fully admit that I don't understand the benefits of it. Also, what is a suction side vacuum? Does it just hook up to the suction side od the pump? I'm terribly new to all of this. Sorry for all the questions.
    Aug 2011
    Virginia Beach
    295
    That's what the vacuum is. I have an 18X48 Ultra frame with a sand filter and LOVE the whole setup! You can always drape the hoses from the old "filter" over the side to make a whirlpool. This will help concentrate the dirt into the center of the pool which makes it easier to see when it's time to vacuum.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
