Thread: salt and borax addition without SWG
    I want to add borax to about 50 ppm for the "feel" of the "softer" water. In reading in the pool school, borax raises PH - is this ongoing or just at first?
    I also want to add salt to about 2000 ppm - I have read where with SWGs some must routinely add acid to combat high PH - is this because of the salt or the SWG?
    I have also learned that the salt does not dissipate or get lost in backwashing and is lost only through splash out - is the same true of borax?
    Thank you in advance.
    38,371
    Re: salt and borax addition without SWG
    Borax raises the pH at first, then acts as a buffer
    pH rises due to the SWG, not the salt
    Yes. salt, borax, and CYA are all mostly only lost through physically removing the water.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Crystal
    Just to clarify, you want 50 ppm of Borates. Using Borax is one way of doing that.
    The Borax itself raises ph and you need to conteract that with Muriatic Acid addtions. Another way to add borates to the pool is Boric Acid which is almost ph neutral. Read: http://www.troublefreepool.com/so-yo...how-t4921.html
    swg
    You do lose salt to backwashing and splashout, but you do not lose it to evaporation. Same with Borates.
