Thread: Low CH
    Low CH
    Pool store person said may need to add calcium increaser if level is too low. (haven't tested mine yet as trying to just clear it up right now). He said if there is not enough calcium in water that it will be pulled from "wherever" it can, like the liner and make it brittle.
    I have read on here that calcium hardness does not matter in a vinyl liner. Why is that? and is he feeding me "pool store" Poo?
    Lizzieann,
    27x54 AGP with Waterfall, 18,500 gallons, Waterway Sand filter- Waterway 1.5 hp -1 speed pump , TF-100 test kit, BBB method.
    22,551
    Re: Low CH
    Yep, he's feeding you a line.
    I've had zero (yeah, you read that right, ZERO) CH (Calcium Hardness) for as long as I've owned the pool and the liner is still as supple and flexible as it was new. And that's been about 5 years.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Low CH
    What he meant was "I need to sell you something."
    Don't fall for high TDS/Nitrates/Phosphates either. I've never had mine tested and my pool is crystal clear.
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Re: Low CH
    Low CH in a liner pool is not an issue as there is nothing to erode (no plaster/grout), the water is not corrosive enough to attack metal either so increasing your CH is just an expense you dont need. Only thing I would say it gives you is the flexibility to use Calcium Hypochlorite if you see it at a good price if your CH is low already.
    Stuart Murray
    Scotland UK
    UK NPPOC
