Thread: Alternative Salts
    Apr 2013
    Dallas, TX
    59
    Alternative Salts
    Another thought question for the chemistry nerds: What would happen if you used Ammonium Chloride or Potassium Chloride in your pool instead of Sodium Chloride salt? If you didn't have a SWG, would it do anything? If you did have a SWG, would the SWG work?
    ~15k gal IG pebble pool/spa w/ water features, Goldline ProLogic + SWG, 2x Hayward Northstar pumps, Hayward Booster Pump, Hayward 60sqft DE filter, 400k BTU Hayward heater, Hayward Viio Turbo pool cleaner, TF100 test kit
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Alternative Salts
    It works with KCl just fine...I seem to remember some old conversations regarding sodium intake and diabetes, and people were using potassium chloride instead. You just need more of it (by weight) to have the SWG work correctly; probably need a certain molar concentration or something...I'm sure others will have that answer. Ammonium will react with chlorine (as well as being algae food) so would not work at all.
    It won't make any real difference unless you are drinking the pool water, but you can use potassium chloride if you want. You will need 1.17 times as much of it as you would need of regular salt.
