Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: New Build in Phoenix Az. - NoFear!
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Specs are in the signature. The Layout and dig are starting next week (Week of april 28th). Honest feedback is appreciated!!
    IG, 18K gallons, 100' Perimeter, 565 SF surface area, 980sf interior area, Max Length -36', Max Width - 16', Pentair 520 Clean and Clear Cartridge Filter, Stenner Chemical Injection System (Chlorine, Acid Coming Soon) , Pebble Tech - Blue Granite, Pentair variable speed filter pump, Zodiac MX8 Cleaner, Multi-Colored LED Lighting, Travertine coping & Decking, Boulder Water Fall....
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: New Build in Phoenix Az. - NoFear!
    looks pretty sweet! You might want to think about getting more umrella sleeves installed. I've seen quite a few people around here that wish they had more to block the brutal sun we get. I wish I had one every 4 - 6 feet around my pool especially on the south side of the pool. Good luck with your build and keep the pics coming.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    38,535
    In the drawing it looks like they have the floor drains plumbed into the skimmer. It would be better to have the floor drains plumbed separately to the equipment pad with a valve to adjust between them and the skimmer.
    It also would not hurt to then add an equalizer line on the skimmer where the floor would have been attached.
    In fact, is that skimmer placement on the downwind side? I would consider a 2nd skimmer on the opposite end of the pool as well.
    I would also consider shifting the light to the right a little (is it a color light?) and adding a 2nd on the far left. Although this is less important if you are just going to have white lights, the reds just do not travel far in the water.
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Quote Originally Posted by Shane1
    We have a sleeve in the baja step. We have a over hang umbrella that we use in addition. Alittle bit of az sun is a good thing!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Quote Originally Posted by NoFear95
    Maybe so...but if you dig way back to late last summer, you'll find threads where people are looking for ways to cool their pools, because a dip in 97 water in 110 heat isn't really all that refreshing.
    Nobody says you have to use all the sleeves at once, but it's a whole lot easier to install them now. That's what sharing information here is about - nobody has time to make every possible mistake personally.
    Skimmer location above steps seems unusual. Make sure that if umbrella is in the baja step, that you can still walk down the steps without it being in the way. Just coping with no deck? Plumbing lines could be bigger to reduce load on pump. I would rather point light across the length than the width as light will go farther than it spreads even if they set the lens properly. Just my opinions...
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Response from the Builder, "The skimmer is placed in a convenient location for visibility, and tucked behind the boulders. It is also close to your pump for maximum efficiency, but also to save you money from running it farther.
    I tend to find that placing a skimmer solely on the most common wind direction isnt all that helpful. You can see at this link just how much it changes month to month in AZ. http://www.wrcc.dri.edu/htmlfiles/westw ... ml#ARIZONA
    If you'd like to change the skimmer location, let me know where and I can price it out for you. Keep in most base pools have 3 returns, on yours however I did 5 and placed accordingly."
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Builder said, "We do "separate suction" on pools with infloor cleaning. With a Vac cleaner and dedicated line for it, we usually do not split the skimmer/MD suction lines.
    We can if you'd like, but it's an additional $280.00. " Worth the extra costs?
    As for the skimmer placement, "Our break point for adding a second skimmer is usually 650sf water surface area. You're at 565.... again, let me know if you want to add a secondary skimmer. Depending on location you'd be looking at roughly $390.00." Worth the extra costs?
    The LED light is color, one of them being white. You can pause it on any color, or let it scroll through the colors on what they call a "light show".
    38,535
    There are advantages to the separate pipes ... reduced suction headloss because you have 2 full pipes. And the ability to isolate the floor to drain some water if required.
    Having 2 skimmers would eliminate the problem of shifting winds ... do you have trees nearby?
    From what I have seen, the "white" light for the LED is when all the colored LED are on ... There may not be actual white LEDs which are brighter. I have not seen a thread where someone regretted getting 2 lights, but a few (mine included) that wished I had 2. My light shines along the length and red, orange, pink leave a very dark shallow end.
    Of course all options are up to you, we can only offer our wish lists.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    No trees nearby at all. I plan on putting some in at a later date, but they are going to be of the desert variety so debris will be minimal to non-existent.
    I really appreciate everyone's feedback. I do have a budget, so I'm trying to get as much as I can given it.
    We had a pool in our prior house so I tried (within my budget) to get as much as we liked and lessen what we didn't.
    I know someone asked about the decking. Pool guy is not doing that (wanted $11-12sqft), my trusted landscaper is willing to do it for $7sqft. That savings over 1000sqft adds up...
    38,535
    Lol ... desert variety trees ... I hope you avoid mesquite and palo verde trees as they are a MESS. Most palm trees are not much better, especially when they get to be 30 feet tall and you have to pay someone to cut the dead stuff off or enjoy fronds falling in the pool when the wind blows.
    When we moved in to this house there was a huge mesquite between the house and pool ... constant mess. Cut it down. There is another huge one behind the fence past the pool. Just cut half of it nearest the pool down last weekend before all the stuff starts falling.
    Hard to find good non-messy trees and plants.
    Apr 2010
    Buckeye, AZ 85326
    619
    Lol ... desert variety trees ... Hard to find good non-messy trees and plants.
    Roger that! We went round and round, searched every website and talked to lots and lots of people. We could not find a tree that fit the bill. So we have a treeless back yard. With the exception of a newly planted multi trunk Mediteranian Fan Plam. There is no perfect tree when you have a pool
    2' Powerfall
    Here is a site I found from the AZ Municipal Water Users Assoc that lists low water use trees that are pool friendly (low debris and thornless). http://www.amwua.org/plants_for-pools.html Alos other shrubs, plants, and flowers.
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Quote Originally Posted by AZHeat
    Very nice find, thank-you!
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Update on our Pebbletech choice, tile and decking.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    A good tree would be a shoestring acacia (Acacia stenophylla)...there is leaf drop, but the leaves are big and thick and stringy, so easy to clean up. None of the tiny leaflets common with mesquites and palo verdes
    May 2013
    Phoenix, AZ
    2
    Just got done with my pool and would recommend at least one more light. I have 3 (one Intellibrite and 2 smaller Globrites) and wish I had done one more Intellibrite in the main body. We used the Globrites to light up the baja step/entry area and cove sitting area/table and they are awesome. Little suckers put out a lot of light. Overall the lighting is ok but a 2nd light in the main body would just have added a bit more "pop". I think you will have some dim areas with just the one light. I feel your pain on trying to stay in budget! We made a few changes along the way that put us over by about $2500 but well worth it for things we couldn't go back and do later.
    On your decking, I'd suggest mixing up the colors so it's not all solid white. A neighbor just did all white travertive and it's uncomfortably bright (to me anyway) in the middle of the day. Our PB clued us into this when we were looking at decking and after seeing in person, he was dead on. We used a mixed blend of colors that's not nearly as bright.
    Enjoy it, already looks like it's going to be a long hot Phoenix summer... LOL.
    19k gal IG, 45' x 15', Deep Blue Pebble Radiance, Pentair Intelliflo & Whisperflo, CC+ 420 cartridge filter, Easy Touch 8, Intellichem, Intellibrite and GloBrite LED's, Autelis controller, In floor cleaning, Twirlybird thearpy jets, Travertine coping/decking
    I recommend 2 lights as well. I put in a 500w and 60W standard light for now with the expectation to change them out in a year or so with color LED. I cut out over $1000 from my build cost going this way.
    You may also want to consider putting a step out on the far left bench
    McKinney, TX
    Pool build in progress, 14.8K gallons, OK flagstone copping (sealed), IG Gunite/Pebblesheen (Blue Granite), Pentair intelliflow 3050 vs - svrs, Pentair IC20 Salt-Gen, 60 sq ft Pentair DE filter, 400k BTU Pentair (NG) heater, Polaris 280 with Booster, Dual Time Clocks with freeze protect feature, Pool (1) 500w (1) 100W Spa (1) 100w lights, (2) Skimmers, 4 Pool Returns, 6 Spa Jets, water features incl (3) 12 scuppers on 12 x 31 raised beam, (2) Gushers on tanning ledge, and double cut spa spillway. controlled by easytouch 8
    http://www.troublefreepool.com/under...t56120-40.html
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Finally got the layout done...should be digging tomorrow!
  20. Back To Top    #20
    I think we have exact same selections in tile, the noche travertine, and a similar gray pebble.
