Results 1 to 11 of 11
Thread: Have a leak
    Apr 2013
    Virginia Beach
    44
    Have a leak
    I was running my filter for about 2-3 days and everything was fine. Shut it off and turned it on today and it sounded like a loose belt. The "squealing" stopped after about a minute. After that the pump started to leak but I could not see where. Shut the pump off and the primer lost pressure and the water level in it went down, any ideas??
    22,000 gallons - salt
    In ground
    vinyl
    Hayward DE Filter Model 6020
    22,550
    Re: Have a leak
    Most likely the seal leaking and water got to the bearing and it's toast. You can try replacing the seal and bearing or you cna replace the seal and motor, or you CAN replace the entire pump. Depending on your level if handyness I'd go for a new 2-speed motor and a seal kit.
    Apr 2013
    Virginia Beach
    44
    Re: Have a leak
    What causes that
    In ground
    vinyl
    22,550
    Re: Have a leak
    A lot of things can possibly cause it. Old age, running the pump dry, dirt getting to the seal, Infant mortality, all sorts of things. It's really hard to say what caused it.
    Apr 2013
    Virginia Beach
    44
    Re: Have a leak
    is there any way to tell exactly what is wrong w it? i plan on taking it apart tomorrow
    In ground
    vinyl
    Apr 2013
    Virginia Beach
    44
    Re: Have a leak
    pump is only a few years old and does running dry mean no water in the pump? if so this has not been happening. I inspected the pump more, after I turn the filter off the pump releases about 1/2 the water back to the pool. I am going to try and find the leak in the morning, and possibly replace all gaskets/seals on pump. what worries me is the noise it has been making, any suggestions?
    In ground
    vinyl
    22,550
    Re: Have a leak
    If you're getting air into the filter then you need to find the leak first.
    Apr 2013
    Virginia Beach
    44
    Re: Have a leak
    I have looks every place and cant find the leaks of water or air on the pump or filter. It looks like the water may be coming from under the pump.. I am going jto try and clean all rings and gaskets today. When doing this I am going to turn off the breaker for power also close off the valve to the pump, anything else I should do?
    In ground
    vinyl
    Apr 2013
    Virginia Beach
    44
    Re: Have a leak
    buying a new hayward pump. any suggestions on where to get it? I am going to be installing myself and a lot of places near me (in virginia beach) will not sell the pump to me because I am installing it. Thanks
    In ground
    vinyl
    Feb 2008
    Denton, TX
    5,061
    Re: Have a leak
    Well, there are a number of places online to buy pumps from. poolsupplyworld.com. Places like that.
    Apr 2013
    Virginia Beach
    44
    Re: Have a leak
    That web site worked out great.. my next question is should I get the same pump or something energy efficient? Current pump is the Hayward - SKU #: SP2610X15 . Are tax kick backs around for energy efficent pumps? Also how often do pool pumps need to be replaced? Some people say they have never replaced them some say every few years.. thanks!
    In ground
    vinyl
