Results 1 to 14 of 14
Thread: Can I use the extension cord?
    Apr 2013
    South California
    69
    Question about connection:
    I have intex sand filter and SW system.
    The outside outlet is GFCI.
    The place i want to put them is bit far away from gfci outlet. Can I use extension core (12 gauge x 25ft) with the power surge (for more connections)? I know the manual recommends to plug directly to outlet.
    Summer Escape 4k gal-AG
    Intex sand filter 1600 GPH
    Intex SWG model 54601
    Taylor K2006 kit & Taylor Salt Water Test Kit K-1766
    Installed 4/29/13
    Re: Can I use the extension cord?
    Some people do, but because of the safety risks I recommend that you do not.
    Not to sound like I'm questioning judgement here. But if the extension cord is the same or greater thickness as the original cord, what would the safety risks be..? I'm only asking because I'm not completely sure why. Is it due to the length the electricity would be traveling through a cord exposed to the elements?
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    The risk is that the cord is sitting on the ground, in a puddle, and then someone steps in that same puddle.
    If the connection point is on the ground that's a danger, if the cord gets some cracks in it and water gets in that's dangerous.
    Water can splash out on it.
    I know someone with an oval AGP that uses a heavy gauge extension cord on the ground, personally I think it's crazy.
    Think of people's safety, especially if you have kids, wire it properly.
    22,551
    It's that whole propensity for damage thing. Whip out the weed whacker, stumble on it when carrying the beer, Get happy mowing, and then there's the electricity and water thing that cramar mentioned. Well you get the picture.
    Feb 2011
    Petaluma, Ca
    665
    Isnt it plugged into a GFCI outlet? I though that would protect from shocking dangers.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Would you want your kid stepping on it, in a puddle of water, even with a GFCI?
    I wouldn't.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I also agree with everyone else, nix the ext cord. 25ft isn't that far to run electric or for that matter any distance isn't too far.
    Jeff
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by cramar
    Not trying to say this is the proper way to do it, I was just clarifying that a GFCI is in theory designed to handle this.
    I do have my cover pump plugged into an extension cord during the winter which I taped the plugs together then put heat shrink tubing over, I don't leave it "in a puddle" though.
    jkurl's Avatar
    Fairfield, ca
    141
    Quote Originally Posted by bobby1017
    You can make this more weather proof by wrapping the plugs with vulcanizing tape, the electrical tape, followed by scotch coat and this will give you some more protection from the elements. We do this for outside connections on antennas and other different type of connections on our ships we have in the coast guard.
    I agree w/ everyone else ditch the cord, run the electrical so it is safer for everyone and protects you equipment as well. What I mean by that is you now have a dedicated electrical run in conduit that will keep it out of the elements if done correctly.
    Pool Size: 20 x 40 Free Form Inground Plaster Pool w/ a shallow cove.
    Gallons : ~23K Jandy CL580 Cartridge Filter, Jandy e-pump 1.5HP
    Polaris 280 w/ Booster Pump, AqualinkRS PDA4 Remote, Aqua-Pure SWG
    Jandy LED Pool Lights (2), Heliocol 500 Sq. Ft solar rack system
    Feb 2011
    Petaluma, Ca
    665
    I apologize for my bad sense of humor in my previous response, my original question was just about the gfci outlet protecting from that scenario.
    I cleaned it up ... behave , Thanks, jblizzle
    Apr 2013
    South California
    69
    Thank You all for the responds guys,
    It turns out that the cords on the sand filter and SW are long enough to place where I wanted them.
    To be more clear, if I used the ext. cord, I would use the 2" PVC to contain it. My original question was about the current if it safe to use the ext. cord
    Edit to add another question (didn't want to create another thread to crowd the forum )
    The water return from the SW system to the pool through 2" pipe. Because some of modification, I cut it in half then install 1" pvc (Tee), then back to 2" pipe before water returns back to the pool. Is there any problem with flow?
    I want to make sure it doesn't hurt the SW
    Installed 4/29/13
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    1" is pretty small. I would stick to 2" if you can, but wouldn't go less than 1.5". What are you try to accomplish? Maybe we can help with alternatives.
    Apr 2013
    South California
    69
    I installed the Tee because I wanted run a pvc pipe to make like a water fall. I tried 1-1/4 pvc and I couldn't put it inside the SWG's tube.
    In this link he used 1 1/4 but I had no luck. Gee, I almost gave up when tried to stick the 1" pvc in.
    http://www.youtube.com/watch?v=xWwRwd3B ... h_response
    On this link, he didn't use the pipe from SW. He used 2"pvc, what the connectors he used there, anyone know?
    http://www.youtube.com/watch?v=MiYPRIjUrL0
    Installed 4/29/13
