Results 1 to 19 of 19
Thread: Seeing if the BBB method can work
    We put in a 15,000 gunite pool with quartz last summer and have been using standard chlorine pucks with a chlorine feeders. I am interested in moving away from these and seeing if the BBB method can work. I do have a few questions:
    1. Is there ever a need for "shock" or do you just add more bleach?
    2. Can you use bleach and chlorine pucks? Basically, I would want to have pucks in the feeder and keep it off until I am out of town and need some chlorine to be automatically added?
    3. Is there possible problems with doing bleach and pucks?
    4. Is there any amount of time that you should not swim in the pool after adding the bleach?
    Thanks in advance for everyone's help. This is a great forum. I wish I found it earlier before constructing the pool and after dumping hundreds at the pool store.
    15,000 gallon quartz finish, in-floor cleaning, Jandy CV580 cartridge filter, Jandy pump, Jandy heater, chlorine feeder and ozone
    Re: Seeing if the BBB method can work
    Welcome to TFP!
    1) You can just use bleach. Chlorine is chlorine, regardless of what form it comes in. However, some forms include other things that you may or may not want in your pool. For example cal-hypo includes additional calcium, trichlor include CYA and lowers the PH. Bleach had the advantage that it only adds chlorine. Also, shocking is something you do, not a product.
    2) If you want and your CYA levels aren't too high.
    3) Not normally. Don't pour bleach directly onto undissolved tablets, that can create chlorine gas which is highly poisonous.
    4) That depends on how much you added. As long as the FC level is below shock level for your CYA level there is no need to wait.
    Thanks so much for answering the questions. Just so I am clear, shocking is done by adding a lot of chlorine / bleach instead of what is marketed as "pool shock". The product says to do it once a week. Do you add double the amount of bleach once a week or does the BBB method not require any "shocking".
    38,361
    Welcome to TFP!!!
    A lot of your questions can be answered by reading Pool School (button at the upper right of the page).
    The shock PROCESS is only done when there is a reason too (like algae showing up). Most members NEVER have to go through this process because they maintain adequate chlorine levels on a daily basis.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Correct, shock is correctly a process not a product and is only used in certain circumstances.
    You should really read Pool School, the link is in the upper right corner, it explains all this.
    You need a proper test kit and the pool calculator app is recommended. By the end of 1 summer you'll have it all down.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Shocking is done by adding the amount needed determined by this chart pool-school/chlorine_cya_chart_shock and the pool calculator http://www.poolcalculator.com/
    A lot of people never shock, myself included. People who are on top of their pool chemistry and pool maintenance might only need to shock after a big party, or accident in the pool, or upon opening their pool.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Thanks everyone. I did read pool school but just wasn't clear on a few items. I'm going to pick up some bleach and start this process. Much cheaper than the chlorine and sounds a lot better.
    Smykowski's Avatar
    Sep 2011
    3,065
    Good decision. Keep asking questions, and reread pool school a few more times. It will start to stick.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Do you have a proper test kit?
    Have a basic drop kit but I guess I need the k-2006.
    38,361
    Get the TF100 ... see link in my signature for a comparison. Recently we keep seeing post about quickly running out of reagent to do some of the tests with the K2006 ... that is why the TF100 is a better value, you get more of the reagent you actually need and not the same amount of each.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, davevt98
    I thought your title was funny ...of course it works, just ask the ~44K members of this site (and umpteen more number of lurkers) .
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    The TF100 from this site is your best bet.
    And definitely re-read pool school a few times, I had to, after a bunch of tests and treatments you'll become one with your pool (for lack of a better term) and start to anticipate its needs....like a husband anticipates his wifes needs
    What site should I get the TF100? Thank you.
    38,361
    They all come from www.tftestkits.net (on the East coast) although there is a West coast re-distributor. See the link in my signature.
    Casey's Avatar
    SW PA
    10,450
    Quote Originally Posted by cramar
    SAY WHUT?!!!
    Just had the best laugh!
    P.S. BBB water is so much more cleaner and sparkly looking than puck water!
    Apr 2012
    SW Ohio
    456
    I was a new pool owner last year and started off using the BBB method and it is a very simple and effective process and with the vast amount of knowledge on this site you will have no issues as long as you follow the procedures.it takes me 5 minutes a day to check pH and chlorine and add what is needed per the pool calculator so there is no guesswork it tells you what your pool needs and you add that. And then on Sunday I spend a hour to clean out the skimmer baskets and vacuum and test the water, it don't get any easier than that but the recommended test kit is a must to properly maintain you pool. And BTW I have never had to shock my pool either.......have fun.......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Apr 2012
    SW Ohio
    456
    1 BTW how long have you been using pucks?!
    2 what is your current cya
    Sunny Blues's Avatar
    May 2012
    Illinois
    17
    Hi! Welcome!
    The BBB method DOES work for almost any pool owner. Read, re-read, and then re-read some more. I even made a binder with tabs for each topic that I found myself returning to for clarification when I quickly needed it but couldn't easily find the thread I had first read it in. I print off certain threads or posts for each topic or key info from the pool school and use that binder like the bible. Every time I open it, I learn something new. And like the bible, re-reading the same sentence miraculously opens your eyes to something new each time; always worth the effort. I have a tab for test results and keep my spreadsheets in that section. It's so easy to record our test results to the spreadsheet in the binder and track things during the season. In addition, I read and re-read the posts on this forum. Even today I found four different posts that contained clear explanations to questions I had and I printed them and added to my binder. All-in-all this site is an OFFICIAL pool "school" and the studying is fun and interesting.
    My advice on pucks is to spend some extra time in the pool school with the topic of CYA. It's worth it to understand its relation to your free chlorine. It's a little miracle. But constant use of pucks will only increase it to a level that is not helpful because pucks add Cyanuric Acid to your water in addition to chlorine. The higher that level, the higher FC you need to maintain in your water. And the only way to get rid of CYA is either to drain your pool down or splash a few thousand gallons out when swimming. That's why it's best to just use straight bleach and not add any CYA on a regular basis. Only add CYA in small doses when necessary as a correction, not a convenience.
    There's a beautiful window of 30-60 CYA and if you stay within that, you have less problems.
    Good Luck learning to believe!
    :) 32x16 In Ground 18K vinyl; Hayward S244T sand filter; Hayward H250IDL2 Heater; Hayward .75HP Super Pump; Booster Pump 5060 & Viper; Hayward CL200 feeder
