Results 1 to 7 of 7
Thread: testing PH with the blue kit in the TF-100
    Jun 2012
    Lafayette, Ca / USA
    260
    So, I'm really struggling getting a precise reading on my PH using that blue kit that came with the TF-100 system (K-1000). I just can't seem to discern the color above 7.5 or so ... I mean, it definietly is not as dark as the 8.2 mark - and in fact is like a brighter pinkish color making it higher than the 7.5 mark ... so my 'swag' is it's betwen 7.8 & 8.0 ... is there a more precise method/kit or strips that can give me a better reading? or am I just being too a/r about the results? I hate just routinely adding MA in an attempt to lower it to around 7.5 ....
    thanks in advance - happy summer, finally. (at least for some of us) ..
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: testing PH with the blue kit in the TF-100
    Have you put a piece of blank white paper behind the test vial?
    Jeff
    Jun 2012
    Lafayette, Ca / USA
    260
    yes ...
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    That is my least favorite test. You are being to a/r, get over it! Took me half of my first summer to get over it!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    I find it helpful to
    1) have a white background
    2) hold the test block at arm's length and squint until the numbers get blurry so I can concentrate in the color
    If it's between colors, I can usually tell if it's, say, closer to 7.5 than 7.8, which I call 7.6. It's just practice. As long as the color is peach, not orange or pink, it's okay for swimming.
    38,524
    That is really the best pH test out there. There are expensive digital testors, but their accuracy can be questionable.
    Try using 1 less drop or 1 more drop and see if that helps you match the colors (it should not affect the result).
    If you just keep the water in the "peachish" range and not bright pink, you are fine.
    extended-test-kit-directions-t25081.html#p206394
    Jun 2012
    Lafayette, Ca / USA
    260
    thanks everyone ... will try various approaches.
