The flow rate does not matter. And is actually not very easy to determine unless you have a flow meter.
There is no table for flow rate, because it is a function of everything in your plumbing including your filter ... so at the same RPM, the flow rate will be different for every pool.
You just need to run you pool long enough to keep it clean enough to your liking. This is probably much less than 24/7:
pool-school/pump_run_time
Amazing the articles that are available at your fingertips in Pool School
That link is for the cartridge, I just could not find the model of the actual filter to know how many sqft it is
Oh, found this "OEM CARTRIDGE CX875REM 112.5 SQ. FT. FOR HAYWARD BLUE HAVEN"
So that is much smaller than we would recommend for you pool size. For 22,000 gallons, we would suggest ~320 sqft. What this means is that you will have to keep a close eye on the filter pressure and clean it often when the pressure goes up 20-25% of the clean pressure.
