Thread: testing cold water
    choitink's Avatar
    Southeast Wisconsin
    11
    testing cold water
    Found in a post that CYA should be measured at room temp or higher.
    My water is 42 degrees upon opening.
    CYA measure artificially high or low that cold?
    How about testing FC/CC/pH/TA, etc. at this temp?
    Reliable?
    Thanks!!
    13,300G fiberglass inground pool, 16x33ft Viking Lakeshore
    Pentair IntelliFlo VS pump
    Pentair TA100 sand filter with Zeobrite
    Pentair UltraTemp heat pump, IntelliChlor SWG
    Test kit: Taylor K-2006C
    22,542
    Re: testing cold water
    The only test that;s normally affected by cold water is the CYA test and it can read low if the water is very cold. We usually recommend running all the other tests and letting the water warm up before running the CYA test.
    choitink's Avatar
    Southeast Wisconsin
    11
    Thank you very much!
