Thread: Tiger River Kyber 1994? stays at 89 degrees
    Went to use it two days ago, it was at 89, thought I had turned down the heat.
    Turned heat up, put on jets for an hour, came back, still 89.
    Yesterday, left heat in the middle- 100 +, still 89.
    This morning- still 89.
    The heater must work, I'm in central KS and the dog water freezes at night here....
    Some thermostat, control board, or the heat knob assy.???
    Not a spa guy, but am very much a fixit guy..
    where to start? thanks in advance..
    38,275
    Re: Tiger River Kyber 1994? stays at 89 degrees
    Welcome to TFP!!!
    Don't know much about these setups, but since it is holding a temperature, but the wrong temperature, I would think the thermostat is messed up.
    If you turn the heat dial up even more, does it get hotter than 89? Wonder if there is just an offset.
    Jun 2012
    Goochland, Virginia (outside of Richmond)
    32
    Welcome to troublefreepool.com...
    I may have been the one that aimed you here from another site
    I am sure someone can help you with troubleshooting or replacement info for your thermostat.
    16,800 16'x32' IG Vinyl Pool, Buddy Seat, 7' Deep End
    Hayward Sand Filter(1.5 cups of DE), Pentair Pump, SWG Autopilot Digital
    Taylor K-2006 test kit, Speed stir, Borate and Salt Water Strips
    Polaris 9300 cleaner
    Pool Filled First Time June 14th, 2012
    Previous Pool AG Intex 16' Oval, SWG (5 Years)
    Wherever the temp knob is at, 89 degrees.
