Thread: challenger 3000
    Apr 2012
    Lynchburg, VA
    90
    challenger 3000
    Anyone ever seen one of these?
    Should it be trusted, or should I remove it from the system?
    TIA
    PF
    The Most Interesting Pool Man in The World
    I don't always have clients that want to maintain their pool,
    but when I do, I send them to troublefreepool.com!
    38,524
    Re: challenger 3000
    Looks like it is a system that adds copper ions to the pool ... so we would certainly recommend removing it to avoid potential metal staining or green hair.
    If you maintain proper FC levels, then there is no need for the added copper.
    Apr 2012
    Lynchburg, VA
    90
    Re: challenger 3000
    Should I just turn it off, or remove it from the system completely?
    Thanks
    PF
    38,524
    Re: challenger 3000
    Certainly turn it off. Probably does not matter too much if you pull it out of the plumbing or not. If you do not want the copper in contact with the water at all, then remove it.
