Thread: Zwave simple setup
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Zwave simple setup
    Im in the process of setting up a zwave network and would like to automate my pool pump. I just have a simple pool setup just a 2 speed 1hp pump that runs on low almost always. Any recommendations on a switch. Found this http://www.smarthome-products.com/p-654 ... odule.aspx
    16 x 32 Inground Vinyl 21000, 2 returns, 1 skimmer, 1 main drain. Raypak Heater, Crystal Flo Sand Filter
    22,544
    Re: Zwave simple setup
    That's not a bad unit, but it's been replaced by the LFM-20. I'd probably go for the newer module if it were me.
    Jul 2011
    NY
    51
    I am actively pursuing control of a booster pump and pool light. Depending on how the pump is wired (you may have 240VAC) - you may need to look at the relays here: http://www.functionaldevices.com/ and look at driving that with a zwave 24v relay that you can control through your automation system (something like Mi Casa Verde, not sure what you're using).
    Remember you have an inductive load and what ever device you use to switch the power should be rated accordingly - solid state relays while a little more expensive, typically handle these types of loads better.
    29,700 Gallon Vinyl Roman End, Sta-Rite Max-Therm-400HD gas heater, Sta-Rite S7M120 cartridge filter, Pool Pilot DIG-220 SWG
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    I do have 240 running to the pump
