Thread: My pool timer
    My pool timer
    My pool timer gear are moving, but it won't set. I have to do it manually, it is the common yellow dial. It is set right with markers, what do I need to replace?
    15,000 IG, plaster, 200 sqft cartridge filter, 1HP, built 2000
    new pool owner
    lboyle1
    30,432
    Re: My pool timer
    I'm not sure what you mean by "set". It won't turn on and off? Is it an Intermatic timer?
    Re: My pool timer
    Yes, set meaning hrs to be on( on and off markers)
    new pool owner
    lboyle1
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    Re: My pool timer
    Sounds like you need the trippers for turning on and off. The second one down are what most use. HD or lowes should have them. http://www.intermatic.com/en/Products/T ... ppers.aspx
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    30,432
    Re: My pool timer
    It sounds like OP has the lugs (trippers). Are they screwed down tight?
