Results 1 to 7 of 7
Thread: Replacing the vinyl liner - inground
    Jul 2011
    Brookfield, WI
    132
    Greetings,
    I think I had a post with this subject, but am unable to find... so here I go again.
    We are replacing the liner this year. Most of it have already been removed and measurements were already taken. Now we have to decide on the design of the new liner. The pool person recommended that we order the 20mil instead of the 28mil as it sits better and "hug" all the corners better. Since this is totally new to me, I figure I would ask here for more education on that. Also, the floor of the pool will need a bit of resurfacing and I am contemplating doing it myself. I am not sure however what I would be getting myself into. Would this be something that I can do? He said that the material alone would be over a $1,000. Also, still on the liner, is there a site where I can see reviews for brands?
    Thank you so much for this forum and for all the replies. Be well
    Miriam
    20 x 44 in-ground vinyl
    Hayward Pro-Series High-rate sand filter (S310T)
    Nature2 Zodiac chlorinator
    Clarksville, TN
    126
    Re: Replacing the vinyl liner - inground
    Check out this site. Seems like a good company. http://www.kaydenmfg.com
    On the floor repair, unless you are good with a trowel or have experience with finishing concrete, I'd leave it to a pro. Some concrete contractors in my area also work on poolcrete bottoms so you may get a better price dealing direct with them, since most pool builders sub it out anyway.
    34,000 gal., 20x40 Roman, IG Steel/Vinyl, 500# Hayward Sand Filter, 2HP Ecostar-VS, Savi Note LEDs, Autopilot Digital 220 SWG
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    I went with a GLI with their gold warranty as I was advised GLI had a good reputation paid 1100. Just had my liner replaced this week. Here is a couple pics of the liner design its 28/28 Ocean beach I believe. I struggled to decide on a pattern. Decided to try something different so I went with the tile pattern.
    16 x 32 Inground Vinyl 21000, 2 returns, 1 skimmer, 1 main drain. Raypak Heater, Crystal Flo Sand Filter
    It's looking awesome and this pattern has a unique touch. I think if any person wants to build a pool in his house so he should to visit the GLI. How many days they have taken for this job?
    Jul 2011
    Brookfield, WI
    132
    Quote Originally Posted by pooly1
    This pattern is the same one as I like most. I may go with that one.
    So, now the issue remains the vermiculite/pool-krete thing. It is so darn expensive to have it done, and the pool can use a good new coat of that. I am very tempted to do it myself. I can work with the trowel, but not with finishing concrete. I have installed several ceramic tile flooring, but again, not sure if that makes any difference. I am going to talk to the contractor doing the work, and if I can have an understanding of how much to scrap off and details of the pool-krete material I think I can do it. Not sure if it has to be done in one single day or if it can be done in over a spam of days. Anyone?
    Thanks. Be well
    Miriam
    Nov 2011
    Moberly,MO
    1,010
    Unless your krete is crumbling it needs nothing. If there is rough spots you could fix those with a little krete mixed in a bucket.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Jul 2011
    Brookfield, WI
    132
    Some areas are a bit crumbly and it was soft when we removed the liner. The deeper end's walls are not the most even and will need lots of patching. The shallow area is where the crumbly is found and it is rough at areas. The contractor said we can do only patch, or do a new coat at the shallow and patch the deep end, or do a new coat in the entire pool. The cost got me wide wake, hence the reason for me thinking of doing it.
