Results 1 to 12 of 12
Thread: Lowes Muriatic Acid and Salt Pool
    Was looking on the Lowes website to see if they still have muriatic acid so I could go by and pick some up before I open the pool for the season. Noticed it was a different brand than I remember from last year - Crown is what they are carrying I guess. Checked specs to see what concentration each version is (one around 15% and the one I was looking for around 31%) and noticed that both say they are not compatible with salt pools. ?
    Am I missing something? I admit, I'm a little rusty in my pool-think since it's been a few months.
    19x43 Inground Vinyl Pool, approx 22 years old, no main drain, 2 (lopsided!) skimmers, 2 returns.
    1 HP Pentair Superflow Pump
    27" Hayward Sand Filter
    AutoPilot SWCG
    Aquabot T-4 Cleaner
    38,463
    Re: Lowes Muriatic Acid and Salt Pool
    That would be news to me ... I can not think what one has to the with the other ... especially since even non-SWG can have a lot of salt in them just from using chlorine.
    EDIT: Where did you see that incompatibility mentioned? I am not seeing anything like that.
    EDIT2: Oh, I see it in the Specs. I think someone does not know what they are talking about. It even says on the bottle for use in pools ... not sure how salt would change that.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Lowe's and Home Depot are little hard to follow when it comes to MA.
    In my area, Lowe's usually has their "everyday" MA which is the Crown stuff at 15% and in the garden/pool center they will have the pool version (usually Kemtek or similar) in a low concentration also 15%.
    Home Depot has the same setup but oddly they have a third type in the garden center that is the 31%. I prefer this one as well as it takes less to make adjustments and here is the silly part...they are the same price for 2 gal. Clearly 31% is a better value too.
    Oddly, HD doesn't put the stronger stuff on their website but they'll list the weak stuff. My guess it has do with hazard level. The weak stuff is classified as a "consumer commodity" just like the 10% bleach, but the strong stuff has a corrosive hazard label.
    If I want strong stuff and HD is out, I have to go to my local (non-national chain) pool store. Price is pretty comparable. ~ $5-6 /gal
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Feb 2008
    Denton, TX
    5,061
    My local Kroger store carried the same stuff as HD does. Same brand and 31.45% strength but they sell them as individual bottles. It's also cheaper than HD, bottle to bottle.
    Apr 2011
    Warner Robins, GA
    245
    Same here my Lowes is 31.45% strength individual bottles.
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    In Lakeland FL they both (Lowes/Homedepot) sell in the 2-Pack (1 Gallon containers) 31% stuff. Outside by the pool items.
    Apr 2013
    Millington, Tennessee
    51
    Found these at Tractor Supply in the paint aisle.
    30K Gal 36'X54" AGP, Eco kleer 22 Sand Filter 55GPM, Installed June 2010, Waterway 1.0 Hp Pump (Installed April 2013), Taylor-2006 test kit, Previously Perma salt system, BBB Method from now on.
    38,463
    Wow. I pay less than 9.99 for 2 gallons of the 31% stuff from the local pool store ... they are good for something
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    I pay just over $10 for two gallons at my locally owned pool and spa supply.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yep, I usually can get it for under $4 a gallon here at fleetfarm
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    I believe I paid $18.80 for 4 gallons of 31.45%. Plus a generous sales tax. And I already paid the deposit, I just had to return the empty jugs.
    Apr 2012
    SW Ohio
    456
    if you have a Rural King store close by they have 31.45 baum M/A for 2.99 a gallon right now it is 3.99 regular price they also have the team 20 mule borax for 3.49 a 76 oz box
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
