Results 1 to 18 of 18
Thread: Is there a TFP business card?
    Jun 2007
    SF Bay Area
    441
    SeanB,
    Is there a TFP business card that you could post to the Forum? I'm getting tired of scribbling "www.troublefreepool.com" on a scrap of paper for people who have just been pool-stored at the local pool store. This way I could just hand them a professional looking card with the TroubleFreePool blue logo and the web address. You could literally have hundreds (or thousands) of people from TFP handing out cards to people who seriously need professional help with their pools.
    [Disclaimer: As much as the local pool store's chemistry advice is to be avoided at all costs, I really do appreciate this store for things I need in a hurry such as repair parts for skimmers, pressure-side cleaners, valves, etc.]
    Titanium
    p.s. could you have the cards done by 4 PM? That is when I plan on going to the local pool store.
    p.p.s. just kidding !!!
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Here is one I just through together. I'll try to come up with something more professional soon. Thanks for spreading the word!
    EDIT: I have removed my version and am attaching new one's created by our member, MeSue. See my post further down the thread with the new cards.
    Thanks Sue!!!
    Attached Files Attached Files
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Jun 2007
    SF Bay Area
    441
    SeanB,
    Your "thrown together" business card looks pretty darn good to me.
    How do I download this jpg so that I can print it out?
    Maybe on future versions of the business card you could mention:
    1) Avoid being "pool-stored"
    2) Use the BBB method - bleach, baking soda, and borax
    Thanks!
    Titanium
    Mar 2007
    Morris, IL
    477
    Right click the image. Select Save Image As, then a dialog box will pop up prompting you to select a location to save it and you can name it whatever you like. Then if you get some business card sheets from wall mart, you should be able to print it to it. At least that is if it is the correct size. It looks like it is though. The business card sheets will tell you what to do to print them. I used to print my own cards for my computer repair business and I think it was price wise comparable to having someone else print them.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    SeanB's Avatar
    Mar 2007
    2,622
    Thanks. I'll try another one from home with photoshop. This was done at work with paint, which I don't like.
    You should be able to right click on it and print it or save it.
    You could always copy it and put a bunch of them on one page so you won't waste paper.
    TFP Founder
    Jun 2007
    SF Bay Area
    441
    SeanB and sevver,
    Thanks for the right click, File Save As advice. For some reason my Mac right mouse button doesn't work this way, but I got the left button to do the same thing while pressing the Control key.
    SeanB, If you do another TFP business card using PhotoShop, could you go ahead and make two versions? One version being the single card and the second version being the full page of multiple cards.
    Thanks again.
    Titanium
    Mar 2007
    Morris, IL
    477
    How to Create Business Cards in Microsoft Word.
    This is where you can see how to Create Business Cards In Microsoft Word.
    Quote Originally Posted by [url=http://support.microsoft.com/kb/170130
    Microsoft[/url]]Creating a Single Business Card or a Single Sheet of Business Cards
    1. On the Tools menu, click Envelopes And Labels.
    2. On the Labels tab, click Options.
    3. In the Labels Product list, click Avery Standard.
    4. In the Product Number list, click the type of Avery label you are using, such as 5371, 5372, 5376, or 5377 and click OK.
    5. In the Address area, enter the address information for the business card.
    NOTE: To modify the formatting of the address, select the address, click the right mouse button (Windows) or hold down CONTROL and click the mouse (Macintosh), and then click Font or click Paragraph on the shortcut menu. Make the appropriate changes in the Font or Paragraph dialog boxes, and then click OK.
    6. Print your business card, using the appropriate method below:a. Printing a Single Business Card
    To print a single business card at a specific location on the sheet of labels, follow these steps in the Envelopes and Labels dialog box:1. Under Print, click Single Label.
    2. Type the row and column for the print location of the card on the sheet of labels.
    3. Click Print. (On the Macintosh, click Print again).
    b. Printing an Entire Sheet of Business Cards To print an entire sheet of the same business card, follow these steps in the Envelopes and Labels dialog box:1. Under Print, click "Full page of the same label."
    2. Click Print. (On the Macintosh, click Print again.)
    And for people like me who use Office 2007, the differences are pretty significant. Avery is a developer of business card paper that can be perforated and snapped apart. They have posted directions on how to use office 2007 to do it.
    Quote Originally Posted by [url=http://www.avery.com/us/Main?action=software.SoftwareAlliancesDetail&catalogcode=WEB 01&softwarecode=3205
    Avary[/url]]
    The newest version of Microsoft Office Word now includes hundreds of Avery Templates for labels, business cards, dividers and more.
    Find Avery Templates by clicking on the Mailing tab at the top of the Microsoft Office Word screen. Just choose Create > Labels > Options > Avery US Letter, then choose your Avery Product Code.
    You could even use these templates to print onto regular paper, but you would have to cut them out. The business cards are much easier, but paper is much cheaper. Using photoshop to create images is of course way better. I don't know for sure, but if it could get saved as a PNG file you could save it as a layer with a transparent background, and it could be printed to any sort of paper. The thing is, I don't know if word will take a png... worth a shot.
    steve
    What a great idea!
    Quote Originally Posted by SeanB
    This is probably not going to print very well since it is only screen resolution. If you do another one, I suggest making it around 300 PPI resolution. It will look huge on screen but print much crisper. If you want help with it, I'd be glad to do whatever I can. I can make you a full sheet PDF of cards if you'd like. Happy to do something to give back to the community that has been so helpful to me.
    Sue
    Current Pool: IG Concrete / 11,000 gal. / Sand filter / Solar heat / Hayward CL200 / Screened / TF Testkit
    Pool owner since 2001. Thanks TFP for helping me convert off Baquacil after six years!
    Jun 2007
    SF Bay Area
    441
    MeSue,
    Thanks for your help.
    Also, I would love to have access to a "TFP Flyer" that I could copy a whole bunch of and leave in a pile outside the local pool store. Hopefully a couple of curious customers would pick up the TFP flyer and discover that there is a better way of maintaining their pool.
    Titanium
    SeanB's Avatar
    Mar 2007
    2,622
    I think she was talking to me. Sue that would be great - what a wonderful offer.
    Please pm me with the e-mail address you would like to use and I will send you the original logo file -much larger.
    Titanium, I appreciate your zeal, but I'd rather not litter the pool store parking lot. I think the business cards are a great idea though.
    Sean
    TFP Founder
    Jun 2007
    SF Bay Area
    441
    SeanB,
    Awww, geeeez, Dad, you never let me do nothing fun.
    Titanium
    SeanB's Avatar
    Mar 2007
    2,622
    New TFP Business Cards
    MeSue was kind enough to make some propper cards for us that can be easily printed and handed out. Feel free to share them next time you find a pool owner in need.
    Note: Use of these cards does not make you an official representative of TFP, nor does use of these cards give you any rights to reproduce or use the TFP name or logo without prior written permission.
    From Sue, "Attached is a PNG version, a single card PDF, and a couple of layouts in PDF format. The 12 up layout is for someone who will print on card stock and cut themselves. It maximizes the paper usage. The Avery layout should match up with any Avery business card sheets starting with the number 537-."
    TFP Founder
    By the way, I think most business card sheets are the same. If you don't have that specific Avery number, it will probably still match up to other brands of 10-up business card paper.
    Sue
    Jul 2007
    Sahuarita, AZ
    278
    Re: New TFP Business Cards
    LOL! I know it's not really a joke, but it still strikes me as funny. The things you gotta do these days...
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    SeanB's Avatar
    Mar 2007
    2,622
    Yeah, it's probably overkill, but I'd hate for someone to start telling people they are with the site not knowing what kind of person the are or what advice they might give. You just never know about people online.
    TFP Founder
    or mermaids!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Wyoming, Michigan
    93
    These are great! There was a local "parade of pools" around here recently and I was really wishing I had something like this to leave with each home/pool I visited.
    Richardson, TX
    287
    That's great! We have 'referal' cards for our car club, directs them to the site and we all give a big welcome if they sign up and post something!
    If you ever up your lifetime membership or have the funds you should laminate a bunch, send them to new members...that's what our car club does, sign up get a 'welcome' package with a couple of trinkets and a dozen cards to put on other peoples S2000's!
    Works for us!
    Thanks Sean!
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
