Thread: Just moved in
    Just moved in
    Just moved in a new house in Hanford Ca with a 25k pool, S8D110 filter, quikskim, turbo clean in floor system, 1hp motor(new) and waterfall feature. pop ups are leaving debris in all corners and the main drain is not removing debris whatsoever. Just drained and filled and cleaned filters last night to no avail. What should I be looking for to get this up and running correctly?
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Re: Just moved in
    First, read pool school. Your valves may be set so they are not pulling from the main drain. This also explains debris left behind by pop ups, as any that does not float just gets pushed around.
    Post your test results (full compliment) and send pictures of your pool and equipment pad.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Re: Just moved in
    I will post the pics when I get them tonight. I have the quikskim fully on and the skimmer valve set to 90% main drain but still have debris everywhere. It's my first pool with pop ups as my other house utilized the kreeply krawly. Thanks for the quick response as I want to get this under control before it heats up adn starts leving stains.
    38,475
    Re: Just moved in
    I have a Caretaker in-floor system. Always ended up with dirt in a few corners. I would just have to brush occasionally to toward the floor drain or manually vacuum.
