Thread: Pool calculator
    Pool calculator
    Hi to all;
    Using 8.25% chlorine that comes in a 121 oz. contained(COSTCO). Pool calculator doesn't allow for 121 oz. containers so I am deducting about 9-10% from the recommended dosage from pool calculator. Sound about right?
    Gary R.
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    38,281
    Re: Pool calculator
    Well, the number of OZ is still correct. So I am not sure why you would need to subtract 10%??? The jug size only changes what appears in the top white box when you put the mouse over the OZ output.
    Re: Pool calculator
    Thanks Jason!
    You are , of course, correct. I guess I assumed that because there was a way to change the "jug size" it somehow effected the outcome. Faulty thinking on my part, again.
    Back into the corner with my d-cap!
    Regards,
    Gary R.
