Results 1 to 12 of 12
Thread: One Year Later of BBB and High-contrast Opener ;)
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Hi all! You may recall that a year ago I rehabilitated a foreclosure swamp that made local pool tech lore as "the poo pool," or so I'm told.
    Well, half our neighborhood is flooded beyond 100 year levels and with such a high water table and a sump under the pool that is only pumped when the gear is live I though it best to open early to pump off any excess pressure, though our water is only 47 degrees.
    I used the pool guys for the mechanical and cover cleaning but supervised chemistry. (Brought out the drop kit when they went to use strips...sigh...these guys are workers physically and mechanically, but we're never on the same page chemically.)
    We opened to crystal clear water, no new iron stains, sparkling white stairs, and still 3 ppm of FC and 60 TA (have now increased to 70 and increasing FC to 7)
    Of special delight to me was that there was not a single wrinkle in the liner, which lead pool guy predicted would happen if I insisted on keeping "low" (aka normally 70) TA
    Quite a contrast from last year. Tomorrow I'll try to post 2012 vs. 2013 pics.
    So thank you to both those who helped me out at the time, and to all of those who share their knowledge and experience here -- whether you know it or not, you've helped me have the first of hopefully many trouble free openings
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: One Year Later of BBB and High-contrast Opener ;)
    How dare you tease us this way!
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Am on the iPad, don't think it will work, but let me try:
    Ok, very first shot in the "recovery" multi-shot is what I opened to LAST year, second photo is this morning! Woohoo!
    Helpful Links:
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Just another reason for believing in BBB. Awesome!!
    Jeff
    22,553
    If my pool were like that all my water would fall out! :shocked:
    Jun 2012
    Howell, NJ
    977
    How does your pool keep the water in like that? What chemical helps defy gravity? I'd like to add some of that to my pool.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Apr 2013
    South California
    69
    I had to turn my monitor up side down so I can see it clearly
    Summer Escape 4k gal-AG
    Intex sand filter 1600 GPH
    Intex SWG model 54601
    Taylor K2006 kit & Taylor Salt Water Test Kit K-1766
    Installed 4/29/13
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Wow pool inverting to keep things from falling into the pool during the winter, you need to get a patent on that
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Too funny - had no idea the iPad turned the pics upside down...on the iPad, the look upright!
    Helpful Links:
    lee872's Avatar
    Central Massachusetts
    59
    Nice work Swampwoman! Thank you for sharing all you've learned with us.
    35,000 gallons - inground vinyl liner -- sand filter - 1 HP, 50.76 GPM - Aqua Rite T-Cell 15 SWG - Dolphin Apollo Plus - TF-100
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Swampwoman:
    Congrats on another success story
