Results 1 to 15 of 15
Thread: Polaris 280 Hose Swivels
    I have a Polaris 280 & just replaced 2 Hose Swivels 8 months ago, because I noticed them leaking Water from the Middle Solid piece. I replaced them. But now I see the newer ones leaking as well. Are these suppose to release water from the middle part? Thanks in advance.
    20' X 40' Rectangular Gunite Pool with Spa
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Re: Polaris 280 Hose Swivels
    My similar model did the same and replaced them 6 months ago. So far no leaks (other than the connection to the power booster). Mine is 6 years old and thinking of replacing it with a robot. Leaks shouldn't matter if it's doing the job.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Thanks for the Reply. It does get stuck in the corner sometimes & not when it's Resetting. Someone told me to change the Wheel Bearings, but I tested Wheel RPM's and they are at 32 RPM's a Minute, which is Normal.
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Mine gets stuck on the stairs often. Only one front wheel is rotating when this happens. I don't think my rear wheels turn at all (are they supposed to?). It seems to do a great job, I'm just starting to think I' might like a robot better.
    DIY chlorine feed
    BBB
    I'm think all wheels are suppose to turn. I will check if my other wheels stop turning. And if they do, I'm thinking the ones that don't turn need the Ball Bearings replaced. Need an expert here to confirm.
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
    Apr 2009
    Northern Virgina
    55
    All of the wheels are supposed to turn. The single wheel and the front wheel are driven directly by a gear at the end of the drive shaft. If one of them is not turning, then you need to adjust the wheel alignment so the gear shaft meshes with the teeth on the inside rim of each wheel. If there are teeth missing from a wheel, then it needs to be replaced. The rear wheel is driven by the small idler wheel that makes contact with the front wheel. A spring ensures that the idler wheel makes contact with both the front and rear wheels. If any of the wheels (including the idler wheel) have difficulty turning or appear wobbly, then you should replace the ball bearings (2 for each wheel).
    22k gallon IG Anthony free-form pool and spa with PebbleSheen finish, Pentair WFDS-8 WhisperFlo Full Rated Dual-Speed 2HP pool pump, Sta-Rite S8D110 System 3 Grid D.E. 53 sq. ft. pool filter, Raypak R406A 399K BTU cupro-nickel propane heater, Polaris 280 pool cleaner with 3/4 HP PB4-60 booster pump, Goldline Aqua Plus controller and SWG, Inter-Fab G-Force pool slide.
    All wheels turn & I see no wobbling. Again, 32 RPM. So the wheels are turning. What else could cause it to get stuck in a corner, where nothing is blocking it but the Pool Wall?
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I decided to take my Platinum Legend apart since only one front wheel appeared to be driven. Sure enough the plastic teeth on the opposite wheel were basically gone on at least 50% of the wheel. I swapped it with a rear wheel and both front wheels are driven now and no longer gets stuck at stairs. The rear wheels are not driven (no pinion and rotate freely). All wheels are a little wobbly and probably need replacing, but I plan on putting that money into a robot soon.
    As far as sticking in a corner, maybe adjusting the rear thrust jets at a different angle? See page 6 here: http://i.poolproducts.com/pdf/Polaris280.pdf
    Quote Originally Posted by JimM01
    DIY chlorine feed
    BBB
    I'll try Thrust Jet Adjustment. Mine climbs walls a little too high. Will Lower It. Thanks for the help tcat!
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
    Last night it was not working at all. Getting Stuck, Only Turning right & not touching bottom. I tried adjusting Thrust Jet. Did not help. This morning I gave it a harder look. Seems the Front Wheel was Wobbling. Screw was lose. But when I turned to tighten the Plastic screw, I must have tightened too much & the head of screw snapped off. Now I Need to figure out how to get the rest of the screw out. I'll try with some needle nose pliers tonight. Purchased 4 screws for $7.50 on Amazon.
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
    Apr 2009
    Northern Virgina
    55
    Have you tried adjusting the float? I have found this has more effect than the thrust jet, on climbing action. Also, how old is your hose? I just got a new 280 last year and the hose is much more flexible than the hose on my old 180 (hose at least 10 years old). With the old Polaris, the stiffness in the hose would cause the cleaner to only turn one way after spring startup because it was coiled up all winter. Even after laying it out in the sun to warm up, I had to reattach the hose to the cleaner in order to make sure it was not bending to either side. In other words, as the hose gets older (more exposure to sun, chemicals, etc.) it gets stiffer and tends to develop a "memory" where it can bend to one side or the other. No amount of thrust or wheel adjustment can correct this when it happens. You just have to adjust the hose so the bend does not cause the cleaner to turn predominantly in one direction.
    Have not adjusted the Float. I keep it screwed in all the way. Never thought about the hose though. You make some valid points. I'm pretty sure the major problem with mine was the loose & wobbly front wheel, but when I get the Screws I ordered, I will take a close look at all you mentioned Thanks. Also, I hope I can get that stuck screw out. It looks like it's going to be a pain to get out.
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
    Aug 2007
    near the swamp
    806
    280 head float needs to be about 1"-1.5" away from the feed pipe, or a finger and a half width
    Ok. Good to Know. Will Do! Thanks.
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
    So I'm still having Problems with my Polaris 280. Changed all Large Wheel Bearings, even though they were changed 5 years ago. The old ones looked fine.
    I'm posting a Link to a Video I made. It's crawling these days. It use to move a lot faster.
    Go Here: http://www.youtube.com/watch?v=nndCYRGh ... e=youtu.be
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
