Thread: salt settle on the bottom of pool?
    Newbie question here. If I don't run my pool over a week. Is it possible for salt and rest of the chemical to settle on the bottom of the pool?
    33k IG plaster
    Advantage pool pump 1.5 hp
    Compupool cpsc36
    Hayward / Leslie superclear CF 150sq/ft
    TF-100
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: salt settle on the bottom of pool?
    If the salt is already in solution (mixed in no crystals showing) then it will stay in solution assuming you are in the 3000 ppm salt concentration range. Same for the other chemicals, once mixed in they will stay with the possible exception of high calcium and other high metal levels.
    Thank you for the info.
    33k IG plaster
    Compupool cpsc36
    TF-100
