Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Confused after Pool School :)
    Apr 2013
    Cartersville, Ga (Atlanta)
    14
    First off this is our first pool we just moved in 2 weeks ago. Pool looks ok just a little cloudy. I was reading about the filter pump in pool school. I went and checked my PSI while the pump is off and its reading 42 PSI? So I did a backwash and it went up to 52 PSI. By the way when we looked thru the sight window it was very yellow and had little bits of trash in it but then got clear after a minute or so. This was also out first time doing anything with the pump. The previous owner said the pump needs to run at least 8 hours a day. After reading I believe it should be 3 to 4 hours. Is there a way to get my PSI down or my gauge bad? How often should I backwash. Do I use any of the other settings on the pump?
    Its a 17500 gallon pool.
    Chlorine level is good but I need to raise the Ph level according to the pool store.
    17,500 Gallons - IG - Vinyl - Hayward Sand Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Confused after Pool School :)
    Welcome to TFP!
    Your gauge is bad. They fail often. You can get one fairly cheaply at a pool store or a farm store.
    Apr 2013
    14
    Ok I will get one this weekend. Thanks.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Howdy, Robione!
    Unsure of filter type? Not good, especially if you backwashed a Diatomaceous Earth filter and didn't recoat it. Look around the filter for a brand or a model number. Take a picture and post it. Compare it to the pictures in pool-school/visual_encyclopedia . Do something to identify it! It's important.
    Next in importance, after having flow and filtration, is the pool chemistry. Don't trust the pool store. Just go back through some of the older threads and you'll see all kinds of horror stories. Keep studying Pool School, and read up on test kits. You'll need one if you want to have the pool perfect. I do all my own testing, never buy any magic elixirs from the pool store, and you can toss a dime in my deep end and call heads or tails. From the deck. Any day of the year.
    Apr 2013
    14
    Ok Its a Hayward sand filter.
    I'm out of town and had my wife checking things as I read! LOL.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Robione
    Quote Originally Posted by Robione
    This likely means you need to do the shocking process. First, if you have them, post a full set of test results. See: http://www.troublefreepool.com/pool-...efore_you_post
    Apr 2013
    14
    Ok I got the data and filter info:
    Apr 2013
    14
    BTW I have since added chlorine. 3 tablets
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Stop adding tablets, according to the pool store results you posted, your cya is too high already. See: http://www.troublefreepool.com/pool-..._chlorine_pool
    If the results above are correct (pool stores often get wrong cya values), then you need to do a drain/refill of your pool to get the cya down to ~50 ppm before anything else. The problem here is you don't really know if their results are right and therefore you don't know if you really need to do the drain refill. I would encourage you to get an appropriate test kit...see: http://www.troublefreepool.com/pool-...kit_comparison If their results are right, this will require draining about 45% of your water then refilling.
    Then you can proceed with the shocking process using bleach/liquid chlorine to raise the FC level.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    By the way, that filter is about perfectly matched for you pool volume (although bigger is usually better, up to a point with sand filters).
    Richard320's Avatar
    Jan 2010
    18,988
    Great! That means no harm done.
    Everyone else has covered the rest of it.
    Apr 2013
    14
    Ok I got my test kit, how do my numbers look
    [attachment=0:129kdzdh]uploadfromtaptalk1367030550480.jpg[/attachment:129kdzdh]
    38,275
    Are your numbers on the left? FC is way too low. And CH of 8 is not possible, each drop is 10ppm.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Nice phone, I have its big brother
    What test kit did you use? You want to worry about chlorine (FC) first. Since its cloudy, you want to shock. You can see the link above in Linens post.
    - Posted from Galaxy Note II
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Apr 2013
    14
    Yes my numbers are on the left. Yea it should be 80 ppm. It took 8 drops.
    Quote Originally Posted by Vette
    Lol, Thanks. I added 2 Gallons of chlorine. More than I needed but it's going to rain tomorrow, I figured it wouldn't hurt. I will have to read up on how to shock it.
    Apr 2013
    14
    Oh and I got a Taylor K2006
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Excellent!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    On the FC test use the 10 ml sample size and not the 25 ml sample...it saves reagents and you really do not need better than 0.5 ppm FC resolution.
    For now everything look fine except for FC. As mentioned before, you need to do the shocking process: http://www.troublefreepool.com/pool-...king_your_pool
    You shocking FC level is 13 ppm FC for your 30 ppm cya (from poolcalculator.com).
    Apr 2013
    14
    Ok after reading a little bit. I got my pump running and had added 2 Gallons of liquid bleach. I do have some "shock" powder should I add some or should the bleach be enough.
    Also I have a chlorinator, should it have tablets in it and what should I set the little dial on the side of the chlorinator to? Up to this point I have been using one of those floaty things.
  20. Back To Top    #20
    Apr 2013
    14
    Oh and the previous owner had the pump set to run 8 hours a day. From what I have read it only needs to run 3 to 4 hours a day? Is that correct?
