Results 1 to 10 of 10
Thread: Wiring for new Whisperflo dual speed motor
    I'm replacing my old pentair whisperflo motor with a new one - 2 speed with a toggle switch. Like a dummy, I didn't take a picture of how the old motor was wired. I don't want to make a mistake and fry the new motor. 230, black/red/green wire from the panel. On the motor, the posts are marked (in order from the top) 1, 2, and 3 or 4. I've already attached the green to the ground. Any pros out there willing to help me out?
    [attachment=0:3tstgb5y]photo.JPG[/attachment:3tstgb5y]
    Thanks!
    12X24 Oval AGP +/- 7100 gal
    Clearwater 100 cartridge filter
    Hi-Flo 2sp 1hp pump
    Re: Wiring for new Whisperflo dual speed motor
    There should be a metal plate on the side of the motor with a wiring diagram printed on it. If you can't figure it out from that, please post a picture of the diagram.
    38,275
    Where is your speed selection switch? If it is not on the motor, you will actually need another wire to the motor.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    The speed switch is directly on the motor.
    [attachment=0:4bc7wzh5]photo 2.JPG[/attachment:4bc7wzh5]
    Hi-Flo 2sp 1hp pump
    Here is a picture of the diagram.
    [attachment=0:gsn23nav]photo 1.JPG[/attachment:gsn23nav]
    Hi-Flo 2sp 1hp pump
    38,275
    Red or black to the middle of the switch and the other to terminal 1. The yellow and white wire from the switch should already be attached to terminals 2 and 3.
    Thanks for the response, Jason. Wired it exactly as instructed (and as it shows on the diagram). Powered it up at the box, and I only have 1 speed - when toggle switch is up, motor turns off. Any ideas?
    Hi-Flo 2sp 1hp pump
    38,275
    Hmm. There is not an "off" on the switch. Check that the yellow and white wires are connected well (they look like it in the picture).
    Are you comfortable verifying 230 V between terminals 1 and 2 with the switch in one position and 1 and 3 with the switch in the other position?
    You previous motor was 230V right?
    Previous motor was 230V - same model just older. Yellow and white wires are connected well I believe. I'll check for 230V!
    Hi-Flo 2sp 1hp pump
    38,275
    If you see 230V between 1 and 2 (and nothing between 1 and 3) and then flip the switch and see 230V between 1 and 3 (and nothing between 1 and 2), that would mean the switch is working, but the motor may be defective.
    You could also try disconnecting the switch and wiring directly to 1 and 3 and then 1 and 2 to see if both speeds work separately ... of course PLEASE throw the breaker when changing the wires.
