Thread: Should I shock? Can algae grow with near perfect levels?
    Clarksville, TN
    126
    Quick Background on my situation:
    Almost done with a diy build that started 10/2012.
    Installed liner and filled pool 11/2012- no circulation for 3-4 month ,but kept clean at occasional bleach
    added thru winter,water stayed clear.
    Pump and swg has been running now for about 4-5 wks and have following test results.
    FC-3
    CC-0
    CYA-60
    TA-70
    CH-90
    PH-7.5
    The reason I am asking if I should shock is, I noticed a couple of green patches about 8"x 8" on the liner yesterday. I brushed them and vacuumed, but as a new pool owner I don't know if a little algae is normal even with proper test levels and you just clean it or if I have the beginnings of a problem. Since pool school is permanently tatooed in my brain now after over-reading I am guessing I should do OCLT, but I am unsure as a pool rookie. Thanks for any help?
    34,000 gal., 20x40 Roman, IG Steel/Vinyl, 500# Hayward Sand Filter, 2HP Ecostar-VS, Savi Note LEDs, Autopilot Digital 220 SWG
    30,408
    Re: Should I shock? Can algae grow with near perfect levels?
    ANY visible algae is not normal. Your FC is a bit low (should be around 5-7ppm) so you could try elevating your FC up to see if that gets rid of it but I would shock it according to the article in pool school.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by janthony
    As duraleigh said, visible algae is not normal for a properly maintained pool. I would raise your FC level to your pools shocking level and do the OCLT.
    Also, your 3 ppm FC is right at the low limit for your 60 ppm cya and a swg. If sometime during the day the pool drops below 3, then algae can get a foothold.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    [center:1plj0cza][youtube:1plj0cza]uijLXS-IJZM[/youtube:1plj0cza][/center:1plj0cza]
