Ugh, after a long weekend away, and coming home about afternoon yesterday, the weather seemed nice enough to allow me to work a bit at the pool.
My TA is slowly coming down. Started at 300, now down to 225. Outlet is pointed up bubbling at the surface, PH is going up and I am bringing it down with MA. Some days PH measures at 8.0 or thereabouts, and I add 128 oz of MA (31.45) to bring it down to 7.0. At the slow and steady rate I am going, it seems I could get through 9 jugs or more of MA before my TA sees 100.
My CYA is at about 30-40, so I suppose I should up that a touch more.
Lastly, and most importantly, with the time I had yesterday, I was going to take the time to do a good job of vacuuming the muck off the bottom. I hadn't even gone 5 minutes when the inlet plugged up.
Upon disconnecting the hose, I found that the muck consists of a mixture of bug remains, grass clippings, and a few other things. I used the outlet to force water through the hose and drained the waste out of the pool. It was a solid green muck.
I can't really progress that much with the inlet plugging every 5 minutes, so I am trying to come up with a plan to either:
1) Rig up the hose to the other size of the PVC fitting with a reducer/bushing/whatever to get a seal and bypass the inlet screen, shooting the contents straight to waist using the existing pump.
2) Take one of the two other pumps (I have a much older one that may or may not work) and try to prime it with the outlet from the other pump, and use it to vacuum bypassing the inlet screen.
3) Fill the hose with water, and attempt to create a vacuum using gravity and slowly vacuum all the gunk not using any pump whatsoever.
I'm leaning towards starting with 3, and then 2, and then 1 depending on how things work. 3 would put the lowest amount of risk on my equipment. The only challenge is getting the hose to stay below the pool level to draw the water out. Most of the gunk is to one side of the pool, but it would be best if it was sitting toward the back of the pool, closest to the downhill slope.
Guess one question is whether there is a big risk running that kind of gunk in a pump. Or does the pump not care? Using the net or screen just seems to agitate the stuff and not necessarily get it out of there. The pump idea started to work, but the inlet screen has hole that trap the gunk and stop the flow. Any pointers are greatly appreciated.
