Results 1 to 8 of 8
Thread: Test results
    Mar 2013
    Waco,Tx
    43
    Test results
    FC 11.5
    CC .5
    TA 230
    CYA 60
    CH 120
    PH 7.8
    Just added a gal of muratic acid. Ive had a hard time trying to get the TA down. Also had the pool at shock level for a lil bit trying top get the CC down. So its on its way down to normal level. Is .5 ok. And can leaves etc dropping in the pool be the cause of it to keep raising. Hasnt been more than a 1.
    32k gallon Inground lazy L with Vinyl Liner. Pentair Superflo 1.5hp pump with a sand filter. Liquid Chlorine
    38,547
    Re: Test results
    It is not uncommon to occasionally see the CC at 0.5ppm, that is normal and fine. If you see it consistently more than that, then you may have something going on in the water that needs attention.
    Lowering the TA is a slow process, that gallon you just added should lower it by around 14ppm according to the poolcalculator. So, if you can raise the pH and do that about 10 more times, you will be getting somewhere.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Test results
    What does you water look like?
    As for ph, above 10 ppm FC, ph measurements are not valid (ph reads high) so I would not make anymore ph adjustments until you are below 10.
    Mar 2013
    Waco,Tx
    43
    Re: Test results
    the water has been really clear. Just starting to get slightly cloudy but not much. With the TA that high is it bad to open the pool? Or should I wait
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Test results
    Quote Originally Posted by Sack
    This concerns me and suggests that you have not finished the shocking process.
    No way to lower TA without having the pool "open" and running. First deal with the shocking process, then you can deal with TA later.
    Mar 2013
    Waco,Tx
    43
    Re: Test results
    I mean open to swimmers. I dont actually close the pool.
    38,547
    Re: Test results
    The TA does not affect swimming, but if you are getting cloudy, that could be a sign that the shock process is required which would delay swimming.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Test results
    Ohh, gotcha...As jbliz said, high TA is not a problem for swimming. However, I too would make sure you are not fighting algae before opening to swimmers. The best way to know is water clarity and next is to raise you FC level up to shock level ( 18 ppm FC for 60 ppm cya per poolcalculator.com) and do the OCLT.
