Thread: Sand in the wood frame.
    Apr 2013
    South California
    69
    I built a 2x4x8 treated lumber frame and filled it with sand. The frame is big enough to use 18 ft pool but it'll be used on 15 ft pool. It took me one weekend to build and I am so proud of it, but....
    Does sand shift even contained in the wood frame? Haven't thought about it until it's done.
    I will upload some pics later when I get home from work.
    Summer Escape 4k gal-AG
    Intex sand filter 1600 GPH
    Intex SWG model 54601
    Taylor K2006 kit & Taylor Salt Water Test Kit K-1766
    Installed 4/29/13
    Apr 2012
    SW Ohio
    456
    Re: Sand in the wood frame.
    is this for a intex style pool or permanent?
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Apr 2013
    South California
    69
    It's AG pool (summer escape).
    I had built 2x4 wood frame and filled the sand in.
    Installed 4/29/13
    Apr 2012
    SW Ohio
    456
    I would like to see some pictures of it,I think the problem will be water or rain run off but from my experience with my Intex once the pool is full I have not had any issues with rain washing out the sand from: around it I added mulch to the top of my sand and have had no issues
