Ok, so I ordered the Kruiser and it came today. And I'm a little confused (again, as usual )
I have a Doughboy with two skimmers. When I vacuum I have been putting the skimmer lid down on both skimmers, attaching the manual vac hose to the skimmer port and just vacuuming that way. It works ok. But I keep feeling like I'm not doing it right or could be getting better results.
Well, today I get the Kruiser in the mail and I'm reading the instructions. It says for a pool with two skimmers to close one off with the pump valve and connect the hose to the selected skimmer...
Is that something I should have been doing while manually vacuuming?
How do I determine which skimmer is getting closed off when I turn the valve? Nothing was marked or explained at install.
