Thread: Change it from a vinyl liner to a pool without a liner?
    I have a 16 X 32 pool made of vermiculite bottom and polymer sides. The bottom has crumbled and the estimate I got was $2000 -4000.00 to redo. Is there a way to change it from a vinyl liner to a pool without a liner. I have had the pool company put 3 liners in the past 10 year and they don't last. Is there any other solution to change the style of pool (fiberglass, etc.).
    Aug 2007
    near the swamp
    806
    Re: Change it from a vinyl liner to a pool without a liner?
    sure, but it's just about the same costs as putting in a totally new pool because that's what it is
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I would think the real question is why is your bottom failing, and why are you going through so many liners? What excuses were you given by your previous installers?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In my experience premium grade liners can last much longer than the bargain basement liners, also the liners will last much longer in properly balanced pools, by far the number one killer of liners is abuse, often in the form of people dumping chemicals into them and letting the chemicals settle on the bottom without proper dilution, etc. (this includes liquid muriatic acid which is much heavier than water and will tend to sink to the lowest point it can find, this is why is is so important to add acid slowly and in front of a return eyeball).
    Ike
