- May 3, 2007
- 17,087
- Plaster
- Hayward Aqua Rite (T-15)
To avoid a more technical discussion in this post, I moved the discussion to here. These are my comments to tphaggerty.
This is the animation that I was talking about. Note that the panels drain from bottom to top.
So a little refresher on hydraulics seems in order. Static head is the most important thing here. Let's start with a thought experiment to illustrate what is going on.
We have two 23' pipes, one is capped at the top one is capped at the bottom. Both are filled with water but the one capped at the top is also in a bucket of water. The one capped at the bottom wil have a PSI pressure at the top of the pipe of 0 PSI since the top is open. At the bottom, the pressure will be +10 PSI.
For the second pipe that is capped at the top, the pressure at the bottom is now 0 PSI since it is effectively at atmospheric pressure of the bucket of water. However, the pressure at the top of the pipe is -10 PSI. There is still a 10 PSI difference but because the reference has change so has the absolute pressures. By the way, a 2" PVC pipe behaves in the same way as a straw. Try it yourself. It will not drain until air enters the top but you have to pull the pipe straight up out of the bucket of water.
Now on to the solar panels. For a moment, let's assume that the pump has just shut off but the instant before the vacuum release valve has opened so there is no dynamic head and only static head. Pressure decreases with elevation so at the lower end of the roof near the gutters, let's say it is 11.5' above the water level, is at -5 PSI. The pressure at the top of the roof, let's say again it is at 23' above water level, is -10 PSI. So the starting pressure at the very top of the roof is less than the lower part of the roof. Hopefully you can see at least this part. By the way, I have measured the pressure at the top of my solar panels and indeed as predicted by theory, the pressure is lower by the height of the building divided by 2.31. I always like to see theory in action.
Now, at this stage introduce the vacuum release valve. Now, the PSI at the lower part of the roof is at 0 PSI so the weight of the water will pull the water out of the ower pipe. The bottom of the roof is at 0 PSI but because the top of the roof is higher and it is still a closed system no air at the top of the panels yet, the pressure is still at -10 PSI due to the water weight on the return side. So there is still a negative pressure at the top of the roof as so water will flow up the panels to the top of the roof and out the return.
You can prove this concept to yourself with a small amount of hose and bucket of water. Clear hose works the best since you can see that it is full of water and you can see which way it flows out. Hold the hose completely under water until it fills. Bend in a loop such that you keep both ends in the water but the loop extends above the water. No water will flow out at this stage since air cannot get it. Place your thumb over one end and slowly pull it out of the water but make sure you keep the other end in the water. The end in the water is the return side for the solar and the end with your thumb is the vacuum release which has not opened yet. So you should have a tube filled with water and one end in the water and the other end with your thumb over the end and the center of the tube higher than your thumb. Now release the end of the tube with your thumb and no water will come out that end because it drained up and over the loop back into the water through the return side.
Hopefully this is much clear now and you have a way of proving it to yourself.
tphaggerty said:Sorry, you are just wrong! The breaker is a check valve. It is ALWAYS closed unless pulled open by a vacuum. The pump doesn't "close" the breaker when it turns on, it is already closed. There is NO WAY that the water "above" the breaker on the source side is "pulled up to the return line" (unless you have a hard closed source line). It just isn't going to happen that way. Think of the breaker as a one-way hole in your pipe, it doesn't matter WHERE the hole is, if the water is under vacuum, air will flow into the pipe. The only difference that the location of the breaker makes is how easily it opens. The lower it is, the less vacuum pressure it is under when the pump stops, the "harder" it is to open. That is why moving the breaker DOWN the pipe can help if you are getting air in the system when it is running. I agree that it makes sense to locate the breaker high, but if doesn't have to be for the system to work correctly.
I'm not sure where you get your information but vacuum breakers that I have seen are not check valves and are not always closed. The old style use a ping pong ball which floats to close the air vent when water reaches it and have been used for years. There are newer ones which work in a similar way but they all close with positive pressure on the inside to the pipe. This only occurs when water reaches the valve. I have been at the top of my roof when the solar is turned and I can assure that air escapes the valve until water reaches it. I have also taken apart an old valve to see how it works.
Secondly, you are completely ignoring how hydraulics work. I have a more detailed discussion below.
As for the air not being able to displace the water in the "very small pipes in the panel", they aren't that small, believe me. Most panels have panels have internal piping that is about 1/8 to 1/4 in diameter. About twice as big as a normal straw. Air will have no trouble rising up through the water in pipes that size to relieve the pressure.
So have you ever played the soda straw trick? Put a soda straw in a tall glass of water, place your thumb over the end and then pull out the straw. The water should stay in the straw unless you let air into the TOP of the straw. Just because there is air in the bottom of the straw does not mean that the water can flow out.
Go back and look at the powermat site videos. When the pump stops, the water drains down from the top of the system, air is allowed into the system and allows both sides to drain. And your explaination of why the water flows up because the pressure is lower at the top of the system makes no sense when you are allowing AIR into the system. Put a tennis ball at the bottom of the pipe, sure, it will be sucked up as the water drains. But if you OPEN the bottom of the pipe (the equivalent of opening the breaker), do you really think the water is still going to flow up the pipe?
