Results 1 to 9 of 9
Thread: Quick and Easy Siphon
    Stuck in a cold weather pattern in Nebraska and had to "re-winterize" due to projected freezes tonight and tomorrow night. We are getting a lot of rain now and I need to siphon some water out this evening. Does anyone have a quick and easy siphon idea?
    20k gal, IG Vinyl, 2-3 HP Intelliflo VS SVRS, Sand Filter
    Re: Quick and Easy Siphon
    You can easily syphon off water with a garden hose as long as you have somewhere below pool water level to drain the water too. Fill the garden hose with water (put it in the pool and hold one end up to a return jet for 30 seconds should do it) then kink one end so it won't drain, keeping the other end underwater, move the kinked end to below water level outside the pool, and release the kink. The pool will then drain, though it may take a while.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    The vacuum hose will do the same thing, but lots faster.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    How many garden hoses do you have? Do you have a sump pump? Do you have a hose you use for backwashing that is large diameter but also more rigid so that it doesn't collapse on itself?
    What will be harmed if you let it fill up and wait till you can use pool pump to discharge extra water?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Looking at weather in Nebraska for the next couple of days, the lowest I am seeing is mid 20's and that only during the early morning hours with temperatures getting to at least upper 30s during the day. I would just leave it full and run the pump continuously at night and when the temps are below freezing and you should be fine.
    good luck
    32,000 gallon Grecian style I/G 1hp AO Smith replace pump. Hayward sand filter (S-244T).
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by bobby32x
    My pool sets up higher than the rest of my back yard by roughly 2 to 3 feet. Do you think the siphon technique would pull hard enough to vacuum leaves and mud from the pools bottom?
    I am currently at work and not able to work on my pool but I wanted to see what you guys thought. maybe one of you have tried this before?!?
    I doubt it. The water velocity will only be the same as if you stabbed a hole in the side of your pool, less the slowing caused by the friction of the hose walls. You'll have better luck with.a leaf rake and a conventional manual vacuum.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If your only talking a couple of days below freezing I see no point in winterizing, here in Louisiana we get winter lows in the down to about 10 degrees some years, occasionally staying below freezing for days at a time, and most people never formally winterize their pools, most just leave them circulating. It takes time below freezing for large bodies of water to freeze, and moving water combined with heat from the pump should protect your pump and filter unless you loose power.
    Ike
