Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: High PSI on my DE Filter
    Apr 2013
    Virginia Beach
    44
    Hi all,
    I have an in ground 22,000 gallon salt water pool. Took my water sample to local pool store and started to balance everything. I have added shock, DE, and salt so far. After DE was added pool filter was running fine (even with Polaris running). PSI started around 15. After about 4-6 hrs of running my PSI jumped to 20 then 23 and I shut the filter off, back washed and re applied DE. Turn the filter back on and the PSI goes directly to 20. Is this safe? The PSI jumps so fast it sounds like the filter is actually makes a "cracking" type noise momentarily. Any ideas what the problem could be or suggestions?
    22,000 gallons - salt
    In ground
    vinyl
    Hayward DE Filter Model 6020
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: High PSI on my DE Filter
    Welcome to TFP!
    How does your water look? DE filters can need frequent backwashing and cleaning if the water is even a little bit dirty.
    Have you disassembled the filter for a thorough cleaning? DE or other debris can get caked inside the filter and may not always clean out during a backwash.
    Apr 2013
    Virginia Beach
    44
    the water is still kind of green. Lots of pollen over the weekend because of the rain. I cleaned the grid out at seasons end last year. I have back washed several times. When I do it brings down the PSI for about an hr
    In ground
    vinyl
    Apr 2013
    Virginia Beach
    44
    Also when I back wash I can see the water is not 100% clear going out,there are still signs of small debris (leaves mostly deteriorated)
    In ground
    vinyl
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    Sounds like the filter is working overtime to clean out the crud and loading up. I'd at least pull the top of the tank and see how full the grids are. This picture is what mine looked like after the prescribed two minute backwash. the water was coming out clear:
    This is from a year or so later, after using fiberclear instead of DE
    There was a lot stuck between the grids as well
    I just pop the top and get in there with a spray nozzle while the backwash valve (it's underneath) is open and knock it all off.
    A tip I got here: Backwash, open air bleed, let it drain. Close backwash valve and air bleed. Remove clamp. Turn the pump on for just a second. Air pressure will pop the top off. No prying or wrestling required. Open backwash valve and start hosing. Be sure a) the tank is empty before you try blowing the lid, b) you kill the pump as soon as it lifts loose, c) you stand back. It's amazing how fast the pump can fill things without any resistance!
    Apr 2013
    Virginia Beach
    44
    ill give it a shot when I get home in about 6 hrs. I was thinking the same thing. After I clear the filter/grid how much DE so I re apply? same amount as starting from scratch again?
    In ground
    vinyl
    Richard320's Avatar
    Jan 2010
    18,993
    Quote Originally Posted by jrocksinc
    Yes, when the grids are totally clear, it's the same as a fresh fill. If it's just a backwash, no disassembly, reload it with 80%
    use-and-care-for-de-filters-t4086.html
    Apr 2013
    Virginia Beach
    44
    should i back wash you think or clean out the filter completely and start over?
    In ground
    vinyl
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    If you pull the grid and rinse/wash it and then reassemble you should add via the skimmer the full amount of DE that your filter requires. And then after each subsequent backwash it is recommended to add 80% of the full amount required by your filter. The logic being 20% stays in it after backwashing.
    I cleaned mine earlier this last month and it was NASTY. When you cleaned your last year did you do the dishwasher soap soak and subsequent Acid bath? I was amazed at the difference after i got it clean meaning just appearance of the filter.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Did you find it to be a chore last time, or no big deal? I think after doing it once that my opinion is it is not as big of deal as i thought it was going to be. I don't like the not knowing if 20% remained, or 10% remained, or 50% remained after backwashing. I would probably open it up and look after backwashing so i could see how mush was left....
    18'x43' Sport Pool
    Apr 2013
    Virginia Beach
    44
    id rather do it right, ill clean it out pretty well when I get home and post what happened tomorrow, thanks for the help
    In ground
    vinyl
    Richard320's Avatar
    Jan 2010
    18,993
    Remember, we love pictures.
    SW Indiana
    9,199
    While dealing with algae, a good strategy for a DE filter is to run it on filter while you are home and can clean it regularly, then switch to recirculate while you are away so it keeps moving water. Also be sure to maintain chlorine levels or the filter will never catch up with the algae.
    Apr 2013
    Virginia Beach
    44
    what is the best way to maintain chlorine lvls? just leave the chlorine generator on? sorry im a new pool home owner.. first time opening
    In ground
    vinyl
    SW Indiana
    9,199
    Generally a SWCG will struggle to maintain sufficient chlorine to keep up with algae. Algae can consume 10 or 15ppm of chlorine in a few hours.
    Here are some articles from Pool School that will point you in the right direction:
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    Shocking Your Pool
    Apr 2013
    Virginia Beach
    44
    backwashed again then rinsed, turned applied DE, turned on filter and PSI is back to 13-15PSI... looks like alls it needed was a good rinse
    In ground
    vinyl
    38,275
    I highly recommend you read the links that John posted ... and all of Pool School (button at the upper right of page) If you do not kill the algae completely, you will never get the pool clear.
    To do this properly, you need one of the recommended test kits and take control of the pool yourself and not rely on "free testing" that often ends up costing $100s for things you do not actually need.
    Apr 2013
    Virginia Beach
    44
    I did read them and had done most of the steps upon opening. This could be a beginner question.. But how can I tell if there is algae in the pool?
    In ground
    vinyl
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Other than being able to see it, the OCLT is the best way. Raise you pool up to the corresponding shock level for you current cya level (see: http://www.troublefreepool.com/pool-...king_your_pool), then make sure you have your swg off overnight during the test. If you loose less than 1 ppm FC overnight (and your water is crystal clear and you don't have CC >0.5 ppm), you can be fairly certain there is nothing growing in the pool.
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    18,993
    It's green (or brown, or black) and/or
    There's green stuff on the walls and/or
    The water is murky and/or
    There's piles of fluffy stuff sort of like dust bunnies in drifts on the bottom of the pool and they disintegrate into nothingness when you try to brush or vacuum them.
    The surefire test is the overnight chlorine loss test. Chlorine is depleted by two things: sunlight and organic matter (algae). So you test the FC after the sun stops beating on the pool and recheck it again before the sun starts beating on it again and you've ruled out any losses due to sunlight.
