Hi forum folk, I have an in ground pool with vinyl liner. The pool is at least 20 years old (given the age of the chlorinator and sand filter). we bought the house three years ago and the pool has never been right. It has always leaked and we have put up with adding water weekly. Just recently its deteriorated and now if left alone drains to 1/2 full in a week.
Using a dye tester I have located two decent leaks where the water return housing meets the liner and a third leak perhaps 1" below the return (I discovered at least one of the leaks had been bogged up with silicon previously). I siliconed over the leaks and that has arrested the leak a good deal. I am thinking I should unscrew the return and glue a pool patch (a bit bigger than a DVD) to cover all the leaks and re assemble to make a better job of the repair.
I am thinking I should drain the pool to at least a couple of inches below the return before attempting the above OR should I drain the pool completely. I am concerned that the water left in to pool could put tension on the hole in the liner where the return fits and make a tear
Please help !
Please help !
