Results 1 to 9 of 9
Thread: Pool coping will be above deck
    I am re-plastering, putting in new coping, & replacing pool deck. My contractor just told me my deck will be lower than the coping. I don't want to be stubbing my toes. He says my pool was set too high initially fifty years ago. Now I know why they had previously used rocks as coping before. Anyone have suggestions. I am bringing the deck up as high as possible, but can't go higher than my patio doors. I also thought maybe I could create a low spot for a drain between the house and pool. Thanks for helping.
    30,432
    Re: Pool coping will be above deck
    Welcome to the forum. Pictures would be very helpful......especially in this case.
    Ramp it up, put slope from the deck to the coping? No
    Picture wouldn't post. I may try later. By suggesting a ramp, are you saying have a ramp around the whole perimeter of the pool? Wouldn't I have to worry about rain pooling up?
    My phone picture file is too big to post. Here is a crude sketch of my problem. I don't see why a drain wouldn't work. But, I'm no professional by any means.
    I think the pavers must match the coping height, to have ridge there would be a tripping hazard, don't think it would meet any kind of code.
    between the pool & door frame put a deck drain in to get the rain water out.
    30,432
    How much lower than the coping are the pavers? What is the difference in elevation between the coping and the bottom of the door jamb? What is the distance of the door jamb to the coping?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    How was rainwater diversion handle before this current redo?
    What type of decking was there before?
    The pavers might allow for less runoff than say concrete as water can seep through the joints down into the sand/gravel base.
    They make various channel type drains, look like little gutters with a grid on top of them. Goggle image search "channel drains", you'll see some situations where they look quite nice.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    4knights's Avatar
    NE Kansas
    419
    I would ask them to create a slight slope from the coping to a drain line run and then the pavers level to the doors. More prep work but would eliminate trip hazard and toe stubbing while providing a way to drain splash out or rain off the patio.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
