Just purchased the salt water pump for my AGP.
Link: http://www.walmart.com/ip/19336123?wmls ... la&veh=sem
The existing pump needs power and so does the salt pump, do they both have to be plugged in or just the salt pump? Is it ok for the other to pull for water while the other is off and will it function like that?
I followed the direction but it does not indicate if the original pump needs to be on even if the salt pump is pulling anyways.
