Thread: Up and running!
    RJDriver75's Avatar
    Jan 2013
    Yorktown, VA
    11
    Up and running!
    Just had the pool repaired and needed a full drain, so after filling back up I decided to go ahead and open since there was a ton of pollen in the pool. I think I about have it balanced. Test readings are:
    FC: 4.5
    CC: 0
    Ph: 7.2
    TA: 80
    CYA: 30
    CH: 120
    Should I add borax to get the Ph up, which will also increase TA, or should I try aeration to raise the Ph? How long does it take to raise using aeration?
    Thanks!
    Mike
    24'x54" 13,500 gal AGP, Hayward e-100 sand filter, 1hp Power-Flo pump, Diver Dan cleaner
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Up and running!
    Aeration is cheaper, and one good rain will probably do that for you any way.
    38,489
    Re: Up and running!
    What form of chlorine are you using? If liquid, then I see nothing wrong with leaving the pH and TA as is and let the pH slowly rise on its own.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    RJDriver75's Avatar
    Jan 2013
    Yorktown, VA
    11
    Re: Up and running!
    I'm using liquid bleach. I guess I won't worry about it Then. Thanks!
    30,431
    Re: Up and running!
    Leave your pH alone. It will tend to rise naturally and 7.2 is within normal anyway.
