Thread: Jandy1400 another bad tri-sensor
    May 2011
    Sacramento, Ca
    64
    Put in a new 3 port cell with sensor on my pool in 2011. Well I am getting error codes this week that points to a bad tri-sensor. Cell has worked great for almost 2 years.
    Question: The new tri-sensors I see on line show some kind of daughter board, are these better/last longer than older versions?
    My current tri-sensor does not have a daughter board, but it does have black epoxy. Hoping for more that 2 years out of the next sensor.
    Charlie.
    30,000 gallon in ground pool, Jandy 1400 SWG, Jandy valves and controls, Sta rite cartridge filter, Just added solar panels and Starite Inellipro variable speed pump
    I spent a lot of money on drag racing, good whiskey, and expensive cigars. The rest of my money I just wasted.
    May 2011
    Sacramento, Ca
    64
    Re: Jandy1400 another bad tri-sensor
    Update:
    I went ahead and installed a new tri-sensor to get rid of my no-flow problem on my Jandy 1400. This new tri-sensor has the little daughter board on it. It came with wiring adapters to use with new or older units. My unit is 10 years old.
    Good news, the unit has been working for the last 4 days. Even with my variable speed pump when it is running on low speed. There is a small push button on the daughter board, once flow has has stabilized, you push the button for 5-8 seconds, and a small greed LED lights up (which apprently indicates flow) and then shortly after the Flow light on the Jandy comes on. I had to do this only once so it is looking good. Initially there wan no green LED after a while on low speed, but once I hit the calibration button for 5 seconds, all is well.
    So I am hoping this units last longer than 2 years, which is what my last sensor did. The two year old cell seems to be producing plenty of chlorine this year too.
    Charlie.
