Results 1 to 12 of 12
Thread: how important are the "two dippers" for the chlorine test?
    Feb 2013
    134
    I'm getting FC #'s all over the map. The directions call for "two dippers" of the R-0870 DPD powder. This seems very non-repeatable to me. Sometimes the crystals clump together, sometimes a few stick to the dipper. Also there's no compensation for 10 ml vs 25 mL sample? How important is the amount of crystals to the test results? Or can I just add any amount that turns the sample pink?
    25K gal IG plaster pool w/ spillover jacuzzi, 12 Gulf Solar coils (leaking/currently bypassed), ancient Raypak propane heater (rusted/currently bypassed), Pentair 001018 VS pump, 4.9 sq ft Triton II sand filter, Taylor K-2006 FAS-DPD kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: how important are the "two dippers" for the chlorine tes
    If you have one or two undissolved crystals before you start adding drops, you have enough.
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    my experience is I use a heaped spoonful of powder, and providing I get a good solid pink colour after swirling, the result is accurate.
    Stuart Murray
    Scotland UK
    UK NPPOC
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    I pretty much use one just over level spoon full and has been said, as long as I get a good pink........I'm good to go. I always have varying amounts of undissolved.
    The amount you really need varies with the FC level. The higher the FC level, the more powder you need to use. If the sample turns pink right when you add powder, and then goes clear or brown you aren't using enough powder.
    It is always safer to use a little extra, rather than too little. Using too little will give you false low results. Using too much, within reason, won't affect the results.
    Feb 2013
    134
    ok, so the degree of pinkness is not critical to the accuracy of the test? just add enough till it turns pink and stays pink
    38,475
    Yes. As long as the water stays pink you are good.
    Well, yes and no. If the solution goes pink and then clear you have obviously used too little powder. But if you could somehow add just enough to get it slightly pink again that wouldn't be enough. The odds are heavily against that happening however. If you add more, chances are it is more than enough or not nearly enough. Or to put that another way, the range over which it can be slightly pink is very narrow compared to the size of even that tiny spoon. The odds of hitting that narrow range are quite low.
    The rule Stuamurr mentioned, add till you get a good solid pink is a good rule in all cases except one. If the FC level is quite low then nothing will ever turn it a good solid pink. But given your FC level is above perhaps 1 or 2, then the solid pink rule works well.
    Feb 2013
    134
    here are today's test results:
    temperature: 74 avg (needed my wetsuit in the deep end!)
    pH: 7.6
    CYA: ~50
    FC: 2-4
    CC: 0
    TA: 150.36
    CH: 200
    So when I ran the free chlorine test on a 25 mL sample, I got 4 ppm. When I ran it on the same sample in 10 mL size, I got 2 ppm. Am I correct in assuming the larger sample test would be more accurate?
    38,475
    How many drops did you use for each FC test? That is a large difference.
    Was it really 20 drops with 25ml and only 4 drops with 10ml?
    Feb 2013
    134
    sorry, reported it backwards
    10 drops in the 25 mL sample = 2 ppm
    8 drops in the 10 mL sample = 4 ppm
    Mar 2007
    San Rafael, CA USA
    12,082
    At normal FC levels, the main issue with using too little powder, especially if you were to use a 25 ml sample size, is that the endpoint transition is weaker since the dye color before that last drop is less saturated in color since chlorine mostly but not completely oxidizes the dye (i.e. there is an equilibrium involved). For a 10 ml sample size, this usually isn't much of an issue and using a heaping single scoop usually works well for most people.
