Thread: pH TA help...
    Jul 2012
    CA
    240
    pH TA help...
    So ph is at 7.9 and ta is at 60 pool school says to adjust ta first but wouldn't adding s.bi-carb raise ph to 8+? But lets say I adjust Ph first, wouldn't adding m-acid make ta to low @ 6-? Thanks guys, am I overthinking this routine adjustment? Ps... to raise ph use s.carb (regular baking soda right?)
    All other chem is in acceptable range.
    25k I/G ecostar ccplus Polaris plaster
    38,299
    Re: pH TA help...
    I would lower the pH a bit and monitor TA. Raising the TA would result in the pH climbing faster. With the lower TA, your pH may stabilize. Although this assumes you are Not using trichlor pucks.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Re: pH TA help...
    Muriatic acid will only make the PH too low if you add too much.
