Thread: Sand filter gauge
    May 2012
    Henderson, TN
    234
    Sand filter gauge
    I just opened my pool today after warmer temps got here. Everything went as it was supposed to but I did have one issue. I noticed on my sand filter that when it is running (filter mode, backwash, or rinse) the psi is pegged out. This is my first pool. It was my first time closing and is my first time opening. Any ideas what the problem could be? The gauge was not uninstalled during the winter. I'm afraid to run it any because of this issue. Thanks in advance.
    35000 gallons
    Hayward Sand Filter
    Jandy AquaSeries Ei Pure Salt System
    IG
    Pentair Superflow 1hp
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Sand filter gauge
    They seldom survive winter outside. If you have strong flow through your returns, you can safely run it until you get a new gauge.
    May 2012
    Henderson, TN
    234
    Quote Originally Posted by JohnT
    Okay. I'll pick up a new one Monday. And I'll remember to remove it next time. Thanks.
    35000 gallons
    Hayward Sand Filter
    IG
