Can a worn impeller and diffuser (30 years old on Pentair Challenger pump) give the same symptoms of an air leak in the suction line? The impeller is not clogged or obviously broken, but living in the desert it has seen a lot of sand through it.
Without vacuum attached it pulls water ok, but with vacuum attached and increased suction needed the pump basket is starved for water and water is pulled in at a low unsteady rate (a decent pull of water, then down to trickling, then back to a decent pull, then back down to barely pulling water) as seen through pump basket.
